Nelson Bros. Jumbo 1 3/4 HP Model TA
this thread has 8 replies and has been viewed 1225 times
Old 08-28-2015, 08:07:49 PM
ClayMartin ClayMartin is offline
Default Nelson Bros. Jumbo 1 3/4 HP Model TA
How do I find out a production date on a Nelson Bros. Jumbo 1 3/4 HP Model TA Serial 19203 on the tag and stamped on the flywheel?
ID:	233092   Click image for larger version
Old 08-29-2015, 12:24:59 AM
Odin Odin is offline
Default Re: Nelson Bros. Jumbo 1 3/4 HP Model TA
There really isn't reliable dates for the Nelson Brothers engines, although engines using a Wico EK magneto are post-1926.
Yours is certainly an interesting configuration. It has the slanted hopper used on the Maynard contract engines, but solid flywheels where most of the T and TA series Nelson-Built engines have 16" spoked flywheels on them.
Likely a safe bet that yours is a later production given the serial number, since the T I have is SN 5555.
Old 08-29-2015, 07:17:58 AM
Post 1926 is a start. From what I understand the T's had spoked and the U's were solid flywheels. This is a TA with U flywheels and the 3rd style of magneto drive. These mean a later model to me. I am just curious as to when it was built? Thank you for your input.
Old 08-29-2015, 07:22:48 AM
midpw midpw is offline
Yeah....I wish you the best of luck accurately dating a Nelson. My guess is early 30's. Do you know the history of the engine? Could it be assembled from a couple different aged donors?
Bruce in Saint Ignace
Old 08-29-2015, 09:17:50 PM
I believe it to be all original. The serial number on the tag matched the one stamped in the flywheel. I went on a link that had a semi registry going for Nelson Bros. engines. There is not enough data to make a history with these engines.
Old 08-29-2015, 10:58:55 PM
https://groups.yahoo.com/neo/groups/...tions/messages
Did you try here?
The Following User Says Thank You to midpw For This Post:
Old 08-30-2015, 08:09:17 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is online now
Clay, engines similar to yours were available in Marshall-Wells Company 1939 catalog. The engines were available on wood skids or on iron sub-base.
Denis Rouleau
The Following 2 Users Say Thank You to Denis Rouleau For This Post:
Old 08-30-2015, 12:49:55 PM
Mike Monnier's Avatar
Hoarder
Interesting that the ad pictures are flipped relative to the descriptions.
The Following User Says Thank You to Mike Monnier For This Post:
Old 08-30-2015, 01:57:23 PM
I noticed this too. The throttle governor engine clearly shows the hit & miss mixer, while the hit & miss engine clearly has the throttling carburetor on it.
From the sound of things this is a much later production, towards the very end of the type being produced.
The Following User Says Thank You to Odin For This Post:
Nelson Bros Little Jumbo model P info Rod Campbell Hit & Miss Gas Engine Discussion 3 03-24-2009 08:14:34 PM
Nelson Bros. Jumbo ?'s Mike Smith Hit & Miss Gas Engine Discussion 3 12-10-2005 02:19:00 PM
Nelson Bros. Little Jumbo Mark K Antique Engine Archives 1 11-15-2004 01:08:14 PM
Nelson Bros.Jumbo Pollack Pete Antique Engine Archives 2 07-07-2001 12:59:38 AM
Nelson Bros. Little Jumbo Bob Naske Antique Engine Archives 9 03-27-2001 11:41:58 PM
