Delco Lighting Plant
this thread has 1 replies and has been viewed 2144 times
Old 04-29-2002, 11:19:31 PM
Bruce
Default Delco Lighting Plant
I'm into tractors and stationary engines and now this older friend of mine asks me if I want an old Delco 32 VDC lighting plant that his family used on a property of theirs.
Is it worth anything?
I should take it right?
Old 04-30-2002, 12:10:22 AM
Don C. Wiley
Default Re: Delco Lighting Plant
Bruce;
By all means take it. It sounds like it may still be in a building and may not even have any rust on it. Be sure to check around for the cover for the air shroud. They were usually put on a shelf and lost when some one took the genarator out of the basement or building that they were kept in.
If you live in a warm climate the glass batteries may still be intact. There aren't too may of them still left, if they were in a area where the temperature gets below frezzing. When they go dead the acid goes into the plates and leaves the liquid mostly water and they frezze and break the jars.
Post a picture or e-mail me one and I can probably tell you what model you have. Delco-Light made about 80 different models. I might even have a manual and wiring diagram for it.
Good luck with the Delco-Light.
"DELCO DON"
Davey Lighting plant Pettergen Smokstak Down Under 0 01-05-2015 07:38:47 PM
1.5hp Austral 12V lighting plant Emu3hp Smokstak Down Under 3 01-06-2013 03:38:47 AM
Delco or Onan Lighting Plant, Please HELP? Evan Hale OConnor Generators & Electric Motors General Discussion 2 04-11-2010 05:30:50 PM
homelite lighting/plant RICK K ROYER Antique Engine Archives 1 10-13-2003 10:22:01 PM
Delco Light 7B12 lighting plant Peter Smithers Delco and other Low Voltage DC Light Plants 3 03-27-2002 04:30:33 PM
