Continental Tiny Tim Generator
this thread has 3 replies and has been viewed 887 times
Old 03-11-2018, 09:38:41 PM
brownfrog brownfrog is offline
Default Continental Tiny Tim Generator
Hello:
I Just inherited a barn fresh Tiny Tim generator.At least that is what i was told it was. I have found no tag or identifying marks as of yet. It is air cooled and painted blue. It turns over and has a hint of compression. It is all there but someone went wacko with a pair of sidecutters. Does anyone have a manual and/or circuit diagram for this machine? Any help will be greatly appreciated.
Old 03-12-2018, 12:55:24 PM
Default Re: Continental Tiny Tim Generator
These engines do not have much compression to begin with. Comp. ratio about 4:1. They don't displace much either. They don't have a throttle either. They depend on the resistance generated by the generater charging to regulate speed.
Old 03-12-2018, 08:56:55 PM
bartlett0815 bartlett0815 is offline
Brownfrog,
Please post pictures. I have a Tiny Tim generator, or is it a Little Joe? There were a couple of discussions here in recent years so you might find your answer by searching the archives of this site. I'm still not exactly sure which unit I have or how its supposed to be wired, but it does put out some voltage when its running.
Good luck,
Kevin in NC
Old 03-15-2018, 11:30:33 PM
Hello:
No photos of mine yet but this is an example of what is before us. Mine is in better shape Just needs the pushbutton starter switch repaired. Will share photos and info if I find some. It was made by Continental Motors. Probably has a series field for starting and a shunt field for generating like many of the Delco light plants and a cutout. Hope the photo comes through. Cheers!
Name:	Tiny Tim skinny.jpg
Tiny 2 stroke? What is this? A generator? Motorguy1996 Small Air Cooled Gasoline Engines 1 09-25-2016 09:59:21 PM
Tiny Tiger Generator Tom Herd Magnetos, Ignition Coils and Spark Plugs 6 02-12-2016 12:43:23 AM
Really Tiny Generator mixdenny Generators & Electric Motors General Discussion 10 05-07-2011 10:26:16 AM
Tiny 2-Cylinder Onan Generator ? Zira Onan Generators 0 09-18-2006 07:27:36 PM
Tiny Tim 12VDC Generator Tom Jamboretz Generators & Electric Motors General Discussion 1 05-16-2004 11:48:56 PM
