Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Palmer 2 1/2 hp
this thread has 4 replies and has been viewed 1226 times
Old 12-14-2016, 08:29:46 PM
Brian.P's Avatar
Brian.P Brian.P is offline
Default Palmer 2 1/2 hp
What would be about the weight and size of flywheel for this engine
not sure if it's around so my fit a spoke flywheel
the carb cover is gone not sure if the mag will work but the one on the floor looks like it may fit
but may turn the wrong way
thanks
Brian
ID:	270277   Click image for larger version
Old 12-14-2016, 11:06:22 PM
Default Re: Palmer 2 1/2 hp
I have a flywheel off in my shop, can get size tomorrow. When checking the mag rotation, these engines turn CCW when looking at the flywheel.
Old 12-14-2016, 11:12:41 PM
Brian.P's Avatar
thanks
I just came in took the mag off put a wire in it and it has spark the cover has been off the points for years didn't think it would work
and the advance would fit the other if I need it as it turns the other way
so it may a chance to run again
Old 12-14-2016, 11:32:49 PM
a flywheel should be available for this engine, ask on OLD MARINE ENGINE, a lot of these engines were salt damaged.
Old 02-13-2017, 03:17:20 AM
Jetmax Jetmax is offline
Hi sir , doyou have information of my engine ? I dont have any info , even name .
ID:	274844   Click image for larger version
Palmer engine? Ihorse Hit & Miss Gas Engine Discussion 12 02-14-2016 08:14:31 PM
Mod 27 palmer marine John Drabik Antique Marine Engines and Outboard Motors 2 04-20-2012 04:28:01 PM
Palmer NR-2 Ihorse Antique Marine Engines and Outboard Motors 3 11-24-2010 10:33:20 PM
little palmer Ihorse Hit & Miss Gas Engine Discussion 1 12-18-2009 10:32:47 PM
40 hp palmer Jim Cobb Antique Marine Engines and Outboard Motors 2 08-21-2008 12:36:38 PM
