Tatro 32 & 6 volt radio
this thread has 4 replies and has been viewed 1285 times
Old 06-27-2017, 11:32:13 AM
Dennis Craft Dennis Craft is offline
Exclamation Tatro 32 & 6 volt radio
here's another item to check out on ebay; Tatro radio
http://www.ebay.com/itm/vintage-TATR...cAAOSwSzRZUnK4
I looked at this radio again trying to determine what model it could be. I am perplexed about what I see, as it appears to be using 1.5 volt filament tubes and has no vibrator nor rectifier. I can't believe that it has 6 volts used for plate voltage so it must be 32 volts. But it doesn't have a power cord like most 32 volt radios. I believe that the seller listed it as 6 and 32 volt because of the paper label inside the cabinet, which I think is misleading. I believe that the paper label is trying to say that Tatro makes 6 and 32 volt radios. Not that this is a dual voltage radio. If one of our fellow smoke-stackers gets it, I'd be willing to help with restoration to an operable radio. You can always send me a private message. Dennis
The Following 2 Users Say Thank You to Dennis Craft For This Post:
Old 06-27-2017, 04:48:24 PM
Default Re: Tatro 32 & 6 volt radio
Dennis, How do you know for sure that the tubes are 1.5 volts? I didn't see anything in the ad to indicate that, but I agree that the label inside is more of an advertisement than identifier. I tried to make out the pencil scrawl across the back also, but no luck.
I'd suspect it's a 6 volt radio (filaments) and I notice there's a "hole" in the chassis.......a missing part. Now, vibrators date from the late thirties I believe and the general architecture of the cabinet suggests that time period, so it might have had a "can" style vibrator?
Of course, the other option would be a regular, battery farm radio with 45 volts of B battery. I wonder if the seller would be willing to pull a couple of tubes for identification? Or perhaps there's a model number stamped on the chassis that he didn't see?
Edit: On closer examination, one of those tubes DOES look like a UV or UX 199.........1.5 volt battery tube. Now I'm confused too!
The Following User Says Thank You to George Andreasen For This Post:
Old 06-27-2017, 07:10:51 PM
Tom G Tom G is offline
My take on this would be that the label is advertising that the company sells BOTH 6 volt AND 32 volt sets. 6 volt sets for the folks who run their radio on regular battery power, and 32 volt sets for those who have a 32 volt home lighting system. That's my opinion.
Old 06-27-2017, 08:37:12 PM
The envelope of the tubes is tubular. For this vintage (1930's), the only tubes with cylindrical sides were tubes like 1A4, 1B5, 1C6, and 1F4. These tubes were also made with the ST (shouldered) envelope later. Tatro used these tubes in their model EN-64, but this is not that model. This link will take you to radiomuseum.org page for the EN-64;
http://www.radiomuseum.org/r/ltatro_en6_4.html
This link is for a Tatro chassis on eBay. Notice the synchronous vibrator and transformer towards the rear of the chassis;
http://www.ebay.com/itm/vintage-L-TA...EAAOSw-0xYevyT
I believe that Tatro made more sets than what have service info published.
I offered to assist the buyer in electronic restoration because we might not be able to find any schematic for it. So my experience would help a lot. I would like to have it but I have way too many radios now.
Old 07-13-2017, 05:17:03 PM
Okay, here's another Tatro radio. The seller doesn't know what they have and think it's a GE or something based on the patent information. However, this is a 6 volt DC set, maybe powered from a car battery or a 6 volt genset.
The Mallory vibrator is a synchronous type for 6 volts.
http://www.ebay.com/itm/Vintage-1930...UAAOSwd3dZZ7oh
Happy hunting,
Dennis
Vintage 12 Volt Bulbs that fit 120 volt Mike Unwin Lighting Fixtures, Switch Panels and Meters 12 07-24-2016 10:38:20 AM
Interesting---12 Volt Lights off 24 Volt Generator MEP=016b SDHomesteader Military MEP and Aircraft Gen-Sets 10 10-16-2009 08:56:53 PM
Hi Guys! Onan CCK 3CR 120 volt or 240 volt envelopes2007 Onan Generators 26 12-27-2007 09:38:47 PM
12 volt or 6 volt for buzz coils Will Magnetos, Ignition Coils and Spark Plugs 23 03-31-2006 03:19:06 PM
32 volt yes, 32 volt auto start Kohler Frank DeWitt Kohler Generators 4 08-01-2005 08:54:08 AM
