Kohler M8
this thread has 3 replies and has been viewed 575 times
Old 03-07-2018, 10:33:03 PM
Geochurchi Geochurchi is offline
Location: Bartlett, New Hampshire, USA / Toronto, Ontario, Canada
Default Kohler M8
Hi All, this Kohler M8 Magnum requires an optional dideo in the ignition system, no part no. is available,any thought as to what size dideo to use.
Geo
Old 03-08-2018, 10:21:35 AM
gdstew gdstew is offline
Default Re: Kohler M8
Why do you think you need a diode in the ignition circuit??? If you mean charging circuit, there should be one there to keep the battery from going to ground. If that is the one you need just get the one from B & S , comes as a kit
The Following User Says Thank You to gdstew For This Post:
Old 03-09-2018, 01:20:43 AM
391507 is the diode that was inside a fuse holder. Later they went to 393814. I don't remember the number for the connector and wire for the later
Old 03-09-2018, 08:15:38 AM
Is there any value for that diode?
Geo
Vintage Kohler: Help With Identifying This Old Kohler : SethPattillo Unidentified Engines 2 06-24-2017 08:58:34 PM
Kohler Kohler K 161 T (1978) on Troy Built Tiller weak spark youngbill1946 Magnetos, Ignition Coils and Spark Plugs 3 06-10-2015 09:38:11 AM
Kohler Kohler 300W Belt Generator Heelerman Kohler Generators 3 10-09-2014 10:46:38 AM
Kohler 3.5RM62 Spec. 620 H.3.4.5.7 with kohler A-23858 information bobfish1 Kohler Generators 2 08-13-2013 10:21:18 AM
KOHLER of KOHLER Electric Plant rvaccaro2 Kohler Generators 2 05-03-2013 12:52:46 PM
