Fuller & Johnson Western Electric light plant
this thread has 5 replies and has been viewed 551 times
Old 02-27-2019, 02:00:02 PM
nadams nadams is offline
Default Fuller & Johnson Western Electric light plant
Hi Everyone,
First post here, but I've of course done some Google reading of the forums from time to time.
I have a question about a battery charging engine that I've come across and how I can use it with modern batteries.
The unit is a Western Electric "Power and Light Set", which was set up for battery charging. As such, it has no magneto, and was designed to be started from the batteries it was charging. The plate lists voltage as 35/42, and the charging regulator has a plate that says 40 volts.
My biggest question is what configuration of batteries can I use to run and charge with this thing? I'd like to leave the regulator and alternator intact, as the control panel is quite complete. I would like to build some sort of modern battery pack though, to be able to demonstrate it reliably.
Since this is not specific to the engine, but rather an electrical system, I apologize if this is not the correct place for this question.
Old 02-27-2019, 02:46:15 PM
Vanman Vanman is offline
Default Re: Fuller & Johnson Western Electric light plant
That would have been used with a nominal 32 volt battery (16 cells). You could get 4, 8 volt batteries (they're made for golf carts and the like) and connect them in series to make a 32 volt battery.
Keith
Old 02-28-2019, 12:14:43 AM
ulgydog56's Avatar
I agree, in series.....
The Following User Says Thank You to ulgydog56 For This Post:
Old 02-28-2019, 06:33:01 AM
GeneratorGus's Avatar
GeneratorGus GeneratorGus is offline
I have a bunch of 32 volt light plants, they all start and run and charge with three "CHEAP" lawn and garden batteries in series. These plants are usually rated at 40 to 42 volts Don't waste your money on special batteries, save it up and buy more gensets.
GUS
The Following 3 Users Say Thank You to GeneratorGus For This Post:
Old 02-28-2019, 09:27:07 AM
Mike Schweikert's Avatar
Mike Schweikert Mike Schweikert is offline
I have two of them, and I will be using the cheapo garden tractor batteries too. They work with my Delco plants..
There is a large open wound resistor on the back bottom of the switchboard. Its connected across the field as a dropping resistor I think. There is a long section and a short one. The long one is normal charging mode, and the small one is overcharge.
Can someone tell me what ohm reading you get on each section?. Mine are toast and I'm trying to recreate the right rating. The wires are broken everywhere in the roll, so not able to measure it myself.I don't know how many volts its supposed to drop it down to. I'm guessing 32-36v but don't know.
Thank you
Mike Schweikert
Jamison PA
See my videos at: http://www.youtube.com/user/standardtwin1
Old 03-04-2019, 02:20:28 PM
GUS
So 3 of them in series for 36v?
---------- Post added at 01:20:28 PM ---------- Previous post was at 01:18:55 PM ----------
Duh, I see now that you did say 3 of them in series.
More Western Electric Light Plant Mike Schweikert Delco and other Low Voltage DC Light Plants 1 10-22-2018 04:57:25 PM
Western Electric / Fuller & Johnson 15B Lighting Plant Parts Needed MBreen254 Generators & Electric Motors General Discussion 8 09-09-2017 10:26:39 AM
Fuller and Johnson Lighting plant/ Western electric choofer Smokstak Down Under 2 12-29-2014 03:35:22 AM
Need Info: Western Electric 32V light plant Bob Painter Delco and other Low Voltage DC Light Plants 20 11-12-2008 09:38:25 AM
Fuller Johnson light plant NICK Antique Engine Archives 0 08-29-2002 06:36:57 AM
