Rawleigh Schryer, Zeigler Schryer & Rawleigh Engine Registry
this thread has 25 replies and has been viewed 7401 times
Old 06-12-2005, 12:28:39 AM
Michael E. McCracken Michael E. McCracken is offline
Exclamation Rawleigh Schryer, Zeigler Schryer & Rawleigh Engine Registry
I 've started an engine registry for Rawleigh Schryer, Zeigler Schryer & Rawleigh engines. I presently have 30 engines registered from 6 States. If you own an engine(s) or know of someone that does please contact me. Include engines name, HP, SN. Cooling type & your name and address. You will receive a newsletter from time to time and a serial number list sometime in August. Your address will not be handed out to anyone without your prior permission.
I'm planning a National Show June 16-18, 2006 in conjuntion with the Crawford Antique Farm Machinery Assn. Bucyrus, Ohio. (Crawford Farm Show - Bucyrus. Crawford Antique Farm Machinery Assn., Ralph Hart, 3866 Crestline Rd., Bucyrus, OH 44820, 419-562-2956)
The engine registery Mission Statement (Committed to the gathering,recording and sharing of historical facts. Through the registering,exhibiting and just plain old fashion fellowship with the owners of these old engines. To insure future generations the knowledge and instill upon them the passion that we have for this line of fine old gas engines.)
Old 06-12-2005, 08:36:27 AM
Dale Dale is offline
Registered 0
Default Re: Rawleigh Schryer, Zeigler Schryer & Rawleigh Engine Registry
Hi I am up in Canada.I have a Rawleigh 1.5 hp engine out in the garage.i will get the serial number and send it to you today.I am missing the rod and piston for it however and been looking for a replacement for 3 years.Dale
Old 06-12-2005, 10:04:03 AM
David Babcock David Babcock is offline
Question Re: Rawleigh Schryer, Zeigler Schryer & Rawleigh Engine Registry
I Have A 6 Hp Acme. I Believe It Is A Rawleigh In Disguise. Do You Want That Info?? D. Babcock.
Old 06-13-2005, 09:04:58 AM
union trader union trader is offline
Hello
Does anyone have pics of a Rawleigh 2 1/2 engine showing the proper crank guard and muffler? Appreciate any help.
Old 06-13-2005, 10:51:49 AM
David M. Lyon's Avatar
Images: 32
Here is one for you....Got the tag off, restoring it. It is a 2 1/2 E6342
David M.
Name:	small rawliegh tag.jpg
Old 06-13-2005, 11:21:16 AM
Ironman Ironman is offline
David M.-
Your 2 1/2 HP engine will have the letter B as a prefix and not the letter E. This is the early style engine that has the speed change lever on the side of the water hopper. An engine with the letter E for a prefix would be a much larger engine. Take a good close look at your tag again and I think you will see that it is actually a model B. Hope this helps you out!
Old 06-13-2005, 12:13:36 PM
Images: 32
Yeah, You're correct. I didn't look close enough, Just can't see as good as I once did!
David M.
Old 06-13-2005, 07:09:04 PM
Smile Re: Rawleigh Schryer, Zeigler Schryer & Rawleigh Engine Registry
Thanks I got you registered 32 and counting
Old 05-18-2006, 09:54:20 PM
I presently have 95 engines registered. With a few more out there in the wings. Every thing for the show is all set with a good turnout exspected. It has been alot of work but I have learned alot about these engines and met many new friends in the process. Check Harry's Show Calendar June 16 - 18 Bucyrus, Ohio for more info on show.
Old 02-28-2007, 02:53:50 AM
Loren E Loren E is offline
I have three Rawleigh engines. First, a 1 1/2hp Rawleigh/Schryer #Z5368, then a 1 1/2hp Rawleigh -W.T.Rawleigh #AA18698 with a Webster magneto, and last a 1hp Leader with a pumpjack built on and Leader pump attached #Z9321. The Leader is of the same style as the other "Z" style listed but has the pumpjack cast to the rear. I'd also sold another engine to a fellow in Wisconsin, it was #AA11408 and if I remember it was a 1 1/2hp.
I would like to get a copy of any serial list you have. I can send pictures of these engines if needed.
Old 05-09-2007, 01:50:10 AM
Axtion Jim S Axtion Jim S is offline
I just aquired a 1&1/2 H.P. Manitoba horitzontal engine mfg in Brandon Man. It is missing the igniter and the crank gaurd. It has had the governor control lever alltered, and the oiler has been repaired with fiberglass cloth The serial tag lists as being # now git this 666
Old 04-13-2010, 11:57:53 PM
Here's another one for the registry. Picked up today -on the original skids with the original gas tank, battery box and starting crank. Also seems to still have some original paint, but need to clean it to be sure. Nothing broken or missing. Sale listing stated it as a -approx 2hp double flywheel engine. It also has a Duplex Manf'g Co tag -Superior, Wisc.
Data: Rawleigh Schryer, 1 1/2hp, 500 rpm, serial #AA 10075.
I went to the sale to check out the 5 engines listed and was quite surprised to find this in such nice shape, just very dirty.
ID:	77283   Click image for larger version
ID:	77284   Click image for larger version
ID:	77285   Click image for larger version
Old 04-14-2010, 11:04:06 PM
Bob Hanauer's Avatar
Bob Hanauer Bob Hanauer is offline
Here is a photo of my 8hp. I am looking for a pully for it if any one has one drop me a note.
ID:	77333   Click image for larger version
Old 04-17-2010, 10:26:57 PM
Loren added your engine to the registry it brings the total engines on the list to 144. Bob I have your engine listed from a prior owner.
The Following User Says Thank You to Michael E. McCracken For This Post:
Old 04-17-2010, 11:45:35 PM
Did you ever get the show book completed? Are any copies available? How many Rawleigh Schryers did you get in the book??
Old 11-27-2010, 02:02:16 AM
Dagster Dagster is offline
Again the engine changed hands H 3380 8 hp Schryer. How do I get a copy of the registry of owners ? Engine now in Colorado springs, colorado Darrin Johnson 719-331-1759 blower440@msn.com The tag reads "Schryers" not any of the other names so does that mean anything ? what year is the engine ? Any info. for this engine specifically ? THX Darrin
Old 02-14-2011, 05:56:03 PM
How many engines in the registry to date? Has the total increased much?
Thanks,
Loren
Old 02-18-2011, 11:55:46 PM
I currently have 148 engines on the list.
Old 08-30-2011, 08:20:42 PM
ontracks597 ontracks597 is offline
DD19288 4 1/2 hp 400 rpm RAWLEIGH I just found this engine. I am the third owner. It sits on the original buz rig it was ordered with. I do need help finding or fabricating the arm that runs on the governor wieghts, and acuates the push rod. the arm pivots on the cam gear bolt. ???
Old 08-30-2011, 09:07:58 PM
oldproff oldproff is offline
Nice find Bill K
The Following User Says Thank You to oldproff For This Post:
Rawleigh & Rawleigh Schryer engine pictures wanted. OTTO-Sawyer Antique Engine Photos 40 02-13-2019 09:02:53 PM
Help needed Ziegler Schryer, Rawleigh Schryer & Rawleigh Owners Michael E. McCracken Hit & Miss Gas Engine Discussion 11 07-16-2012 11:24:30 AM
Rawleigh, Rawleigh Schryer engines featured Michael E. McCracken Hit & Miss Gas Engine Discussion 11 12-18-2009 03:39:33 PM
Rawleigh, Rawleigh Schryer engines The motor kid pig guy Hit & Miss Gas Engine Discussion 6 12-15-2009 10:30:44 PM
Rawleigh-Schryer Engine Larry Zachary Antique Engine Archives 0 04-16-2000 10:58:48 PM
