Delco 110V
this thread has 3 replies and has been viewed 2258 times
Old 09-26-2005, 12:14:58 AM
Allen L Fry
Default Delco 110V
Hello , I just purchased a delco light plant . It Has a 110V 1.25 KW decal on the circuit board ? It looks just like the 32v generator I have , I have just never seen a 110v delco that style . It is red and black in color , with the origional decals in place . I was just wondering if anyone had seen one like this , and also , how would I set it up too run ? any help with this would be greatly appreciated ! Thanks Allen
Old 09-27-2005, 09:47:14 PM
Default Re: Delco 110V
Allen;
Is it a DC or AC generator? If it has a commutator with segments it is a DC, it it has slip rings it is an AC. Does it have a flywheel magneto, or does it have a coil and points under a cover over the end of the camshaft? If it has a flywheel magneto, there should be a crank handle in the rim of the flywheel to start it with. If it has points and a coil it is going to be a bit more dificult to work with.
According to my information you must have a Model-1271. You will need a 110 volt battery to make it opperate properly. Does yours have a governor? The 1271 uses the battery for a governor. It has a mixer instead of a carburetor and the jet is fixed to provide the proper load to keep it from running too fast, with the battery load. It is similar to the Model-850 except it is wound to produce 110 volts instead of 32 volts for the 850.
If you could post a picture it might help some.
good luck!
"DELCO DON" Southern Illinois
Old 09-28-2005, 12:48:21 AM
Allen L Fry
Don , It has a coil and points setup . It doesntnot have a crank in the flywheel . it looks just like my 32v delco ( unsure of the model ) same carb setup , and everything has the adjustment on the carb just like the 32v ! I will try to get some pics too you if I can get my camera working ! Thanks again ! Allen
Old 09-28-2005, 08:13:44 AM
Mark B Mark B is offline
Allen. I too am currently restoring a 110 vdc Delco. Mine has coil and points and is a model 3KW. Does yours have two gibs on the flywheel or one? Also I have a stack of paperwork on Delco generarators. Let me know if you need anything. Mark in southern Michigan
Delco model 1275? 110v. David Babcock Delco and other Low Voltage DC Light Plants 6 04-20-2019 10:33:26 PM
110v DC? Railroads Generators & Electric Motors General Discussion 28 04-14-2018 10:35:31 PM
Delco 300? 110V Olf20 Delco and other Low Voltage DC Light Plants 13 03-04-2017 10:13:00 AM
220v Lincoln on 110v Flintstone Welding Shop 13 08-20-2015 12:46:50 AM
Configured for 240 wye have 110v between phases roberthvac Generators & Electric Motors General Discussion 16 08-16-2010 08:31:33 PM
