CCK "Points Problem" (resolution & mea culpa)
this thread has 3 replies and has been viewed 1648 times
Old 11-24-2005, 12:01:44 PM
VaughnSimon VaughnSimon is offline
Default CCK "Points Problem" (resolution & mea culpa)
A few weeks ago our beloved old CCK failed us a couple days following hurricane Wilma and I asked you fine people for advice. It died with classic points symptoms (farting, backfiring, surging etc.) so naturally, my snap diagnosis was points. When I found a few drops of oil in the points box, I refined my (mis)diagnosis to "oil-fouled points". I should have noticed that cleaning the points never helped the situation for even a moment and I should not have missed the clue that the engine would always start and run fine for a few seconds before dying. I certainly should have held the "Rope Start" switch down for a few seconds to be sure that the generator was not shutting itself down.
But no, I had diagnosed the problem as "points" and that was the end of the matter.
Inagine my chagrin when the symptoms did not change following the installation of a new set of points! Today, I installed an oil pressure guage and, to my great relief, measured 28 pounds. So the problem is the oil pressure switch. I changed out that sucker last year with a NAPA part because the old sender was oozing oil.
Should I buy the genuine "green" Onan part? Or will it just be the same Chinese POS that I can get at NAPA for half the money?
Vaughn
Old 11-24-2005, 02:39:59 PM
Exclamation Re: CCK "Points Problem" (resolution & mea culpa)
If the NAPA replacement is a direct replacement, it should be OK
Old 11-24-2005, 03:42:03 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: CCK "Points Problem" (resolution & mea culpa)
Vaughn
Vaughn, I have had really bad luck with the Standard NAPA Oil Pressure Switches. They are of POOR quality, and fail considerably more often than
the "REAL" Hobbs Oil Pressure Switches that can the purchased thru NAPA
as well. Spend a few extra pennies for the Hobbs switch and then forget
about it for the rest of your lifetime.
Bruce in alaska
Old 11-25-2005, 03:49:34 PM
Default Re: CCK "Points Problem" (resolution & mea culpa)
Thanks Bruce, that is exactly the type of info I was looking for. My local NAPA was not willing to order the Hobbs or SW part, and their web catalog is not any help. They would be happy to sell me another part like the last one, but I don't consider that an option.
I will Google the part. I think Onan uses a setpoint of 10 pounds. If so, I want a 10# "Normally On" unit. Looks like a Hobbs or SW part # 78151.
Vaughn
Delcolight "stopping" problem solved! George Andreasen Delco and other Low Voltage DC Light Plants 0 07-01-2019 05:23:08 PM
Why don't the "points" 2 cylinder engines start without kickback? Pete Spaco Onan Generators 7 08-03-2017 08:59:02 AM
"Modern" motor, possibly old problem someone might recognize Archaeometrist Garden Tractors and Mowers 14 10-24-2016 05:18:46 PM
Any "Trick" to diagnosing fuel problem? DerekC Hit & Miss Gas Engine Discussion 17 12-30-2007 07:44:29 PM
Maytag Single "balance problem" Tom Herd Maytag Engines and Collectibles 5 09-05-2005 08:03:25 PM
