Delco starting problem
this thread has 1 replies and has been viewed 1725 times
Old 05-06-2007, 06:33:24 PM
Ronnie Dykstra Ronnie Dykstra is offline
Default Delco starting problem
I have a model 850 Delco. I got it running for the first time last night. However the starting lever won't stay up. The engine has plenty of speed. I stuck a screw driver between the starting lever and coil of wire. It had some magnatism. But it won't hold up the lever bt itself.
Ron
Old 05-06-2007, 10:19:54 PM
Default Re: Delco starting problem
Ron;
Your generator isn't producing enough current to hold the starting switch armature up in the run position.
You should be producing aroun 38 to 40 volts when the generator is charging, however it isn't the voltage that holds the armature up, but the current. Several things can cause this. Your brushes may not be making "total" contact with the comutator, comutator not "smooth" and clean, brushes not working freely in their holders, engine not running fast enough, battery fully charged, bad connection from generator to battery. You need enough load to draw enough current to cause enough magnatizum to hold the armature up. If your battery is fully charged you may need to hook up some lights or a motor to draw current to hold the armature up. A rubber band or stick to hold the armature up works, but isn't recomended
The small roller on one side of the armature holds the ignition current to the coil connected. When the charge current drops below a set amount the armature will drop down and disconnect the power to the coil, killing the engine.
It's a good idea to have a voltmeter connected as well as the ampmeter on the control panel. That way you can monitor the charging system better.
The charge current on the ampmeter on the control panel should be around 10 to 12 amps, with about 39 volts.
I hope this will solve your problem. No warrenties expressed or implied.
"DELCO DON" Southern Illinois
Delco 850 special starting instructions Mike Cushway Delco and other Low Voltage DC Light Plants 2 10-23-2018 12:48:34 PM
Starting/stopping a Delco Light 850? George Andreasen Delco and other Low Voltage DC Light Plants 6 09-30-2016 03:10:16 PM
JC Starting Problem Al Jacobson Onan Generators 5 02-13-2010 05:41:08 PM
Delco 850 Starting Question MBreen254 Generators & Electric Motors General Discussion 6 04-23-2009 06:57:41 PM
starting a delco 850 with dead batteries Delco Generators & Electric Motors General Discussion 10 12-18-2005 12:20:45 PM
