Coil, points, plug for Neptune outboard
this thread has 0 replies and has been viewed 3699 times
Old 07-05-2008, 04:21:15 PM
robert roll robert roll is offline
Default Coil, points, plug for Neptune outboard
hi yall', i have a neptune outboard motor, model# 15b1 serial# J16494. have been looking for ignition parts, to no avail. the plate has the name ( R.E. Phelon) stamped on it. also stamped on the plate is ( set points to .020 ). i need the coil which is black type glued celophane looking material with magnets fused into it and a wire and spark plug end with screw end and nut. the points have no number that i can see. the spark plug has the following id#'s (46-M ). one more thing, can the magnets on the flywheel seem ok but lose the oomph to make a spark? right now with the points set and every thing hooked up, there is no spark. as far i can find out the motor was made in 1946. thank you for any help, robert roll
Neptune Outboard Motor Terry Beasley Antique Marine Engines and Outboard Motors 19 07-22-2017 05:16:41 PM
Questions on a neptune outboard oncewaslost1982 Antique Marine Engines and Outboard Motors 1 12-30-2009 08:14:03 PM
Outboard Neptune Engine? Help Please enginesilo Antique Marine Engines and Outboard Motors 3 07-02-2008 12:04:58 AM
Chrysler Outboard ignition coil dparsley Antique Marine Engines and Outboard Motors 10 07-30-2007 01:04:36 PM
Questions on a neptune outboard oncewaslost1982 Antique Marine Engines and Outboard Motors 5 05-01-2007 08:22:24 PM
