Early Style Steam Elbows
this thread has 6 replies and has been viewed 1566 times
Old 11-05-2008, 02:56:10 PM
Dusty's Avatar
Dusty Dusty is offline
Default Early Style Steam Elbows
Does anyone know of a source for early style steam elbows with the rounded shoulders like in this photo ? (As opposed to the squared Taiwan style at the Hardware stores). I can send a photo if you think you might have some lying around for sale. Or will buy them new if someone can help source them. I need three total 1-1/4" NPT. Thanks.
Old 11-05-2008, 08:27:01 PM
DaveWachter DaveWachter is offline
Default Re: Early Style Steam Elbows
HI my name is DAVE i am a plumber by trade and I also have looked for this style of fitting at most supply houses .nofittings just stoupid looks if you have a realy old supply house try them DAVE WACHTER
Old 11-05-2008, 08:35:03 PM
Peter Peter is offline
I am looking for these all the time too, along with other old fittings. I dont think I have any that size. I can go look tomorrow. The "T" fittings are handy too. I need some old style 3/4 fittings right now. You often see 1/4 elbow and tees on the gasoline lines. I assume you need iron, that style is found in both brass and iron.
Old 11-05-2008, 11:42:09 PM
Ed Cooksey Ed Cooksey is offline
I have new one's. They have British taper pipe threads. So you'll need to run a tap in them a little. On 1 1/4 I think the pitch is correct but they are 55 degree so it helps to clean then up. If you have a British engine even better.
$2.50 plus each shipping.
Old 11-05-2008, 11:46:00 PM
You said steam. these are Not high pressure but just regular water pressure stuff.
Old 11-06-2008, 11:27:23 AM
ed, can you provide a link to some specs. matterial. cast steel? iron or brass? ratings? Pictures, prices, sizes and types. Elbow and tees?
I found it difficult to run a tap onto an elbow unless you grind down the tap and might even need to grind off the ends of two expensive taps to make clean tight threads. Tees are easier, naturally the two opposite ends are a piece of cake.
Old 11-06-2008, 12:06:08 PM
Dusty's Avatar
Thank you Ed. I enjoyed a brief conversation on the phone with you. Funds are on the way.
Waterloo Boy, Early Style, Model Engine D. Dean Suhr Scale Model Engineering 2 10-30-2007 09:50:02 PM
4th of July Steam Style! Beth V Steam Stationary Engines, Traction Engines 1 07-04-2007 10:57:07 PM
Galloway 2.25 HP "Early Style" Restoration Dave Mahan Hit & Miss Gas Engine Discussion 6 05-29-2007 03:54:08 PM
Galloway 2 1/4 HP "Early Style" Engine Dave Mahan Hit & Miss Gas Engine Discussion 6 04-23-2007 11:33:21 AM
CARB PARTS FOR AN EARLY STYLE WATERLOO Aaron Abey Antique Engine Archives 0 08-08-2003 09:48:10 AM
