Nelson Bros Little Jumbo model P info
this thread has 3 replies and has been viewed 2356 times
Old 03-24-2009, 04:06:42 AM
Rod Campbell Rod Campbell is offline
Default Nelson Bros Little Jumbo model P info
I'm new to this and may be in the wrong thread but here goes!
I dont know what the lever does on the Webster single magnet mag bracket. It is about 2 inches long and has 2 positions but doesnt appear to have an obvious function. It is to the right of the igniter.Also there is a large lever between the timing cogs and the starter flywheel with about 4 notched positions. I assume it is an advance/retard lever but I am not sure how to use it.
Any advice?
I have nearly completed a 70 hour restoration(yes, I am probably slow) but it looks a million dollars and I made sure it worked (roughly) before I started. I have another one minus some bits only 6 numbers apart from my motor under restoration.Of course being in New Zealand the motor is upside down.
Old 03-24-2009, 06:52:52 AM
Chip Watford Chip Watford is offline
Default Re: Nelson Bros Little Jumbo model P info
Rod,The lever to the right of the ignitor is to advance and retard the timing.It works on an eccentric shaft and raises and lowers the trip rod.The other lever you mention is the speed control and it increases and decreases the spring tension on the detent blade. Chip
Old 03-24-2009, 04:33:57 PM
Thankyou for your reply Chip. Is retard to the right? Also, is pushing in the inlet valve with my finger the correct way to kill the engine?
Old 03-24-2009, 08:14:34 PM
Maurice Weiler Maurice Weiler is offline
Hi Rod, I would not hold the intake valve in while the engine is running . I shut mine down by closing the fuel valve. and yes the lever to the right is the retard position
Nelson Bros. Jumbo Help needed Wallysky Hit & Miss Gas Engine Discussion 7 07-16-2012 11:13:14 PM
Nelson Bros. Jumbo ?'s Mike Smith Hit & Miss Gas Engine Discussion 3 12-10-2005 02:19:00 PM
Nelson Bros. Little Jumbo Mark K Antique Engine Archives 1 11-15-2004 01:08:14 PM
Nelson Bros.Jumbo Pollack Pete Antique Engine Archives 2 07-07-2001 12:59:38 AM
Nelson Bros. Little Jumbo Bob Naske Antique Engine Archives 9 03-27-2001 11:41:58 PM
