Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Kohler Generators
Kohler Generators
Wiring diagram for 1926 model D 1500 watt DC light plant
this thread has 3 replies and has been viewed 2882 times
Old 06-05-2009, 09:12:06 PM
Eeyore 4460 Eeyore 4460 is offline
Default Wiring diagram for 1926 model D 1500 watt DC light plant
Does anyone know where I can find a wiring diagram for this light plant? Thanks!
Old 06-06-2009, 01:28:47 AM
Question Re: Wiring diagram for 1926 model D 1500 watt DC light plant
What do you need? engine side? generator? does it have the auto start option?
Old 06-07-2009, 09:52:52 AM
Default Re: Wiring diagram for 1926 model D 1500 watt DC light plant
It's on the generator side and it does have the auto start. HTH.
Old 06-27-2009, 06:12:21 PM
james.taylor11 james.taylor11 is offline
If you look on http://www.psy.fsu.edu/~thompson/Eng...er/kohler.html ,you will find wiring diagrms for both ac/dc types,I also have a 1926 auto start took me a year to rebuild,but worth it runs like a turbine very smoth,and I used the diagrams on this site,runs in full auto,GREAT,but I do have to say it looks like a later model,different carb,air filter,fuel pump,and exaust manifold,well worth rebuilding,best of luck.
ZC Fairbanks Morse light plant wiring? Jason Delco and other Low Voltage DC Light Plants 7 02-07-2007 07:16:41 PM
Model D 1500 watt, 110v DC, Automatic 32V start William K Kohler Generators 8 11-12-2006 04:17:40 PM
1938 ONAN 32 V 1000 Watt Light Plant Question Alaska Onan Generators 5 03-08-2006 02:26:31 AM
kohler 1500 watt light plant Fred Kohler Generators 1 03-17-2002 01:33:33 PM
Shaft speed for 1500 watt generator Doug Brookens Generators & Electric Motors General Discussion 2 11-16-2000 03:21:31 AM
