Points question on a MCCK
this thread has 1 replies and has been viewed 1091 times
Old 07-01-2009, 06:56:46 PM
BankerHours BankerHours is offline
Default Points question on a MCCK
I have a 6.5 MCCK 3CR/1H, question is concerning the ignition. With the cover off of the points box and the engine running is it normal for there to be a significant spark occuring when the points contact? Ive never monitored inside the box with the cover off while the engine is running and just dont know anything about vintage small engines in general so I just had to ask.
The genset hunts pretty bad and Ive spent endless time trying to correct it by playing with the carb settings. I recently installed a new condenser and points and went to inspect them and noticed the spark. It is a very significant spark, a LOT brighter and larger than the spark you would monitor on a spark plug with it laying on a cam cover and cranking an engine over.
Thanks for all the info and help guys!
Old 07-02-2009, 09:18:18 AM
Billy J Shafer's Avatar
Default Re: Points question on a MCCK
Not uncommon for them to spark. You should try some fuel cleaner in your tanks. Carb may be clogged up.
Ignitor points gap question R. Kern Hit & Miss Gas Engine Discussion 8 09-18-2008 02:12:09 PM
MCCK 6.5KW burns through points quickly Aquafennatic Onan Generators 38 08-09-2008 03:03:01 PM
IHC igniter points question Kevin Weis Hit & Miss Gas Engine Discussion 7 02-19-2007 10:45:03 PM
Mcck ATLNB Onan Generators 8 07-28-2005 06:48:41 PM
Points question Leonard Keifer Small Air Cooled Gasoline Engines 7 06-27-2005 04:37:12 PM
