Delco Light Plant Model 850
this thread has 2 replies and has been viewed 2442 times
Old 09-12-2010, 07:45:32 AM
curt andree curt andree is offline
Default Delco Light Plant Model 850
Trying to get my Delco Model 850 running. Can not seem to get gas to carb. Romoved fuel lines and cleaned. Cleaned out inspection plug screen and hole going down into carb. Noticed there is no check valve on end of tube in gas tank. Not sure if there is supposed to be one. Is there supposed to be a check valve? Checked for spark. Plug is clean. Made spark test by holding the kill lever a distance and got good spark. Noticed that on the starter switch needs to be held half way between closed and open to allow the spark to continue. Engine will only run when I hold the start switch partway open. Any ideas to help? Would like to take her to show next week end.
Also is Delco Don still around in S.Illinois? If any one has his contact info including correct phone would be appreciated.
Curt Andree
Old 09-12-2010, 03:51:29 PM
Default Re: Delco Light Plant Model 850
I called Curt on the phone and I think we got his problems solved.
"DELCO DON" Southern Illinois
Old 09-25-2010, 04:17:55 PM
Delco Plant Starter
I am in need of instructions on how to rewind the two coils on my Delco Model 850 light plant. Also wondering what gage wires I should be using. Ok to contact via my email
<cgandree@aol.com>
My first DELCO LIGHT PLANT Danny in KY Delco and other Low Voltage DC Light Plants 9 10-05-2010 12:02:32 AM
1930 model 752 Delco light plant chiltb Delco and other Low Voltage DC Light Plants 4 06-21-2010 09:33:19 PM
Delco Light Plant Help davekm63 Delco and other Low Voltage DC Light Plants 10 05-28-2010 05:26:28 PM
Delco Light Plant 8-c-3 Chuck Parcher (Ks.) Delco and other Low Voltage DC Light Plants 3 10-06-2006 03:20:04 PM
Delco light plant jon olsen Delco and other Low Voltage DC Light Plants 1 09-05-2004 12:15:35 AM
