Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Gasoline Engines and Power Units
Multi-Cylinder Stationary Gasoline Engines and Power Units Waukesha, Buda, Climax, LeRoi and others.
LeRoi D201 Pump Engine
this thread has 13 replies and has been viewed 3954 times
Old 04-07-2011, 07:50:33 PM
Paso One Paso One is offline
Default LeRoi D201 Pump Engine
There is a Le Rol Engine mounted to a pump I found on some property I just bought. The pump I thought was a water pump on a trailer. On the pump body it has casted in some concrete company in London Ontario. Could it be a concrete pump?? This thing has patent stamps on it saying 1940 Did they even pump concrete in the 40's ??
Name:	2011_0407(010) (Small).JPG
ID:	104244   Click image for larger version
Name:	2011_0407(011) (Small).JPG
ID:	104245   Click image for larger version
Name:	2011_0407(012) (Small).JPG
Old 04-07-2011, 08:00:22 PM
Default Re: Le Rol D201
Here is a few more shots in case anyone is interested in seing them. If anything I need a water pump and was hoping to reserect this beauty
Name:	2011_0407(013) (Small).JPG
ID:	104247   Click image for larger version
Name:	2011_0407(015) (Small).JPG
ID:	104248   Click image for larger version
Name:	2011_0407(014) (Small).JPG
Old 04-07-2011, 08:10:07 PM
trowel
we have been using concret and cement in our country for many years, well before the 1900's, i don't know much about them but thats a nice looking pump for its age,
trowel
Old 04-07-2011, 08:21:54 PM
Heins Heins is offline
That is a water pump, I think they call it a trash pump because it will pump dirty water. I have one built just like it only smaller mounted to a large wisconsin single cylinder engine.
Old 04-07-2011, 08:28:43 PM
I would like it to be a trash water pump as I have a 3 inch trash pump on a Briggs engine and it pumps like crazy and is easy to prime.
This one has about a 6 1/2 inch opening. The thing is not all covered with concrete residual so it makes mw think it isn't a concrete pump just made by a concrete pump company LOL Thanks
Old 04-08-2011, 09:30:54 AM
A cement pump doesn't use centrifugal force to pump cement, they use a piston which moves back and forth. We cleaned out a pond with my pump and it would pump muck, gravel, and water dogs. It will pump anything that will go through it.
Old 10-07-2011, 08:25:12 PM
Anyone know any starter #'s for this engine???
It does not have a starter, I'll have to try find one
Old 10-08-2011, 10:28:12 PM
Ed Malcom Ed Malcom is offline
Email Not Working
Default Re: LeRoi D201 Pump Engine
allis chalmers made these for le roi and are basically W C engines. The le rois have different starters that i think are delco remy. I have three starters on my d 140 engines and none of them have tags and in all my literature i can find nothing for a starter number. Ed the le roi man
Old 10-10-2011, 10:31:47 AM
Tom Marshall Jr.'s Avatar
Tom Marshall Jr. Tom Marshall Jr. is offline
This starter is off a Leroi looks to be similar in size. 185 CFM air compressor. Delco 1107695. mounting holes are 1/2 inch, 2 accrosed from each other, 4 1/8 in. appart. hole in bell housing would be 3 1/4. snout sticks out 3 1/2 inches . eng. was junked no model no.now, just saved the starter. this might help you. if you want a photo send a e mail you can't attach photos here. Tom
Old 10-13-2011, 05:29:08 PM
Thanks Guys for the info..... It appears I won't be needing that starter after all. I took all the shrouding off ectera and the block is cracked so much it bulge the side.
Side note the starter was held on with three bolts.
I'll post some pictures.
I'm now thinking of a transplant engine.
I will also post pictures of the bell housing adapter housing to see if you guys have any ideas.
Old 10-16-2011, 09:11:12 PM
Here are the pictures I promised.
The direction I'm heading is to find a newer engine that will bolt up to the bellhousing. ( re drill if I have to )
The flywheel drive setup looks like it is easily transfered to another flywheel. What are the chances that flywheel would bolt to another engine. ( slim to none )
Name:	Front view pump carriage (Small).jpg
ID:	118435   Click image for larger version
Name:	bellhousing attached to motor (Small).jpg
ID:	118436   Click image for larger version
Name:	flywheel drive side standing (Small).jpg
ID:	118437   Click image for larger version
Name:	Fly wheel crank side (Small).jpg
Old 10-16-2011, 09:37:13 PM
I was surprised how the pump drive to flywheel drive was so simplistic.
Name:	flywheel drive side (Small).jpg
ID:	118448   Click image for larger version
Name:	Pump drive (Small).jpg
Old 01-02-2012, 01:24:00 PM
I now have my transplant engine and in the process of manufacturing a way to couple the old with the new. Here's a picture.
Name:	2011_1211(001) (Small).JPG
Old 01-02-2012, 01:52:56 PM
Here is how I plan to connect the two. I cut the old flange off the D201 Machined the stub to 1 7/8 shaft size and had a keyway cut. I then purchased a coupler half to match the sureflex coupler that was on the new power plant, the old flywheel will bolt to the newly machined flange.
Name:	2011_1210 (Medium).JPG
ID:	124614   Click image for larger version
Name:	2012_0101(001) (Medium).JPG
ID:	124615   Click image for larger version
Name:	2012_0101(008) (Medium).JPG
ID:	124616   Click image for larger version
Name:	2012_0101(010) (Medium).JPG
Leroi D201 Engine powertech84 Multi-Cylinder Stationary Gasoline Engines and Power Units 13 02-24-2018 11:46:26 AM
LeRoi engine/Domestic pump Clark Bigger Multi-Cylinder Stationary Gasoline Engines and Power Units 10 10-09-2009 10:50:04 PM
Need 411 on a LeRoi engine Donald Kuhl Hit & Miss Gas Engine Discussion 3 08-02-2006 12:22:17 PM
Leroi Engine Joe A Antique Engine Archives 1 11-28-2002 01:12:13 AM
LeRoi engine Vic Libby Antique Engine Archives 0 02-10-2002 09:44:09 AM
