2hp IHC Famous Speed Lever?
this thread has 6 replies and has been viewed 1597 times
Old 07-22-2011, 10:40:59 PM
enginekid89 enginekid89 is offline
Default 2hp IHC Famous Speed Lever?
Hello Everyone! Iím in need of some help with my 1914 2hp IHC Famous Pump Engine. I purchased this engine a few weeks ago and the previous owner said if you find any missing parts come back and you can dig through the shop to try to find them. Iíve found almost everything except for what I believe is the speed control lever that would be on the governor side of the engine. The bracket is still on the engine just not the lever or whatever else should be there. The problem is I have no idea what im looking for. If anyone could tell me what Iím looking for or even better show me some close up pictures I would greatly appreciate it.
Thanks for any help in advance.
Adam
Old 07-23-2011, 04:37:04 AM
LarrapMan's Avatar
LarrapMan LarrapMan is offline
Default Re: 2hp IHC Famous Speed Lever ???
Hey Adam,
I assume you are talking about a vertical Famous, either way if you watch this video - http://www.youtube.com/watch?v=PrrTyjQ8uUg i'm sure you will see a good look round the part your after.
Joe
Old 07-23-2011, 08:43:00 AM
Greg-N-CA Greg-N-CA is offline
Go to: http://www.smokstak.com/forum/showthread.php?t=90296
Post #14 has a good view of the lever. I hope you find it!
Old 07-23-2011, 12:20:23 PM
Preston Wells's Avatar
Preston Wells Preston Wells is offline
Images: 37
Default Re: 2hp IHC Famous Speed Lever?
Enginekid be reminded that not all vertical Famous engines had the speed change option. My 1909 Pumper does not have but my 1909 standard does have speed changer. Hope this helps.
"There is more to life than what we see"
www.youtube.com/user/theoldengine1
Preston
FL
Old 07-24-2011, 11:33:40 AM
Thanks everyone for all of your help so far. I belive all of this information will help me fine the speed lever.
Thanks Adam
Old 07-27-2011, 11:20:36 PM
Well Everyone, After going back and looking for the speed lever for my famous I couldnt find it. If any one knows were i might find one please let me know.
Thanks Adam
Old 07-28-2011, 08:43:40 AM
Check with Skip Landis, he's into IHC engines and a sponsor of Harry's. Good luck!
Fairbanks ZC52 Speed Regulator Lever Tom Herd Hit & Miss Gas Engine Discussion 4 08-19-2010 03:35:53 PM
Hercules Speed Control Lever Pat Barrett Hit & Miss Gas Engine Discussion 3 05-21-2010 09:11:38 AM
1937 McCormick Deering LA, with NO speed lever????? Kevin Woodruff Hit & Miss Gas Engine Discussion 9 08-12-2009 12:03:18 AM
IHC LA Speed Control Lever Stevie Hit & Miss Gas Engine Discussion 2 01-08-2006 07:08:36 PM
IHC-LB-Speed Lever Garry Antique Engine Archives 3 07-06-2002 12:21:28 AM
