Delco 8BW3 Battery charging generator
this thread has 2 replies and has been viewed 1700 times
Old 08-30-2011, 09:14:44 AM
M Schwab M Schwab is offline
Default Delco 8BW3 Battery charging generator
My son just bought a Delco 8BW3 Battery Charging Water Cooled Engine-Generator - 800 watt, 32 volt D.C. (Marine) at an engine show. That is all the info I have been able to find ! I have found a LOT of info on the Delco Light Plants but not the marine units.
We are specifically looking for a manual and some pictures of how they should look and their history and types of boats on which they were used.
At the very least, his appears to be missing the point cover. It looks pretty complete.
I will try to get some pics tonight and post tomorrow.
Old 08-30-2011, 12:00:17 PM
Default OOPS, Delco 8WG3 Water cooled generator
OOPS, bad memory on the model number ! See attached pics. It is a model 8WG3 Water Cooled Engine-Generator Only (“L” Head) – 800 watt, 32 volt D.C.(Marine).
Name:	Delco carb side.jpg
ID:	114454   Click image for larger version
Name:	Delco coil side.jpg
ID:	114455   Click image for larger version
Name:	Delco flywheel side.jpg
ID:	114456   Click image for larger version
Name:	Delco pump pulley.jpg
Old 11-08-2013, 09:39:40 PM
FDChief FDChief is offline
Default Re: OOPS, Delco 8WG3 Water cooled generator
That's a good find, but compared to my 8GW3 it is missing a few things. I'm guessing they would have been very similar.
There would have been a control box that went along with the unit. Either a Sentry box or an AB control, I think the early units used the AB control.
There would have been an exhaust manifold with a Sisson choke on it for automatic starting, and a water cooled muffler. It is missing the conduit adapter where the wires come out of the generator also. You can certainly wire it up for manual operation. I don't have any books on it but I do have a cut sheet on the 8GW3 that I can send you. Let me know if you find any manuals on it.
Jeff
The Following User Says Thank You to FDChief For This Post:
Onan BFA - How do I know the battery is charging? hcfarm Onan Generators 16 06-22-2010 06:07:50 AM
5.0 CCK battery charging help needed Robert S. Onan Generators 14 12-12-2008 08:33:47 PM
2.5 LK battery charging problem Jim Kinler Onan Generators 2 11-24-2007 03:40:37 PM
Battery Charging AndyG Trucks, Trailers and Hauling for Shows 10 09-25-2005 04:27:33 PM
6.5NH Battery Charging shawnb Onan Generators 2 12-11-2004 10:08:10 PM
