International Harvester I4 Help
this thread has 9 replies and has been viewed 3297 times
Old 10-11-2011, 07:13:26 PM
willys lover willys lover is offline
Default International Harvester I4 Help
i have a 1944 ih i4 industrial i picked up last year.i replaced the carb, points plugs wires etc.has mag.its had a small miss right along now all of a sudden it backfires pops runs terrible. it seems to be the worst when you first increase throttle.i have been told to check everything from stuck valves to cracks in the intake manifold.can anyone help me narrow down my search?i also wondered about the governor.thank you for any help.
Old 10-11-2011, 08:24:48 PM
Arrow Re: IH I4 Help
If the running improves when you give it some choke you found what the trouble is....... ......fuel.
Try spraying some WD40 around the intake manifold flanges where it bolts to the head. If the engine picks up you know exactly where the trouble is.......
Old 10-11-2011, 08:31:40 PM
bocephus_k6 bocephus_k6 is offline
Default Re: IH I4 Help
Sounds to me like you may have a stuck valve, easy enuf to check.
Brian
The Following User Says Thank You to bocephus_k6 For This Post:
Old 10-11-2011, 08:36:06 PM
Exclamation Re: IH I4 Help
First, do a compression test. Find a bad cylinder (more than 5% off mean pressure - over 10% between low and high readings)? Check valve clearances. With the engine running, short out one plug at a time, and see if you find the one that is causing the backfire. Afterfire out the exhaust may mean a fouled plug or a bad cap. Look carefully at the interior of the cap, and the rotor. If there is a lot of corrosion, or carbon tracking, replace. Decent idle and poor performance under load may point to bad ignition wires. I have had sets with severe leakage, new out of the box! Run the engine in the dark, you may see high voltage leakage! As Craig says, choke on improve performance - check carb. How old is the fuel?
Old 10-13-2011, 07:38:54 PM
Default McCormick I4 Help
can anyone help me? i have a 1944 i4 industrial. i bought it off ebay last year. the guy i got it from knew little about it, he had taken it in on trade for a lawn tractor at his dealership. he had plans to restore it but never got to it. it had sat 6 years when i got it.i put new points in it and gas and it fired right up.its had a small miss in it right along. i picked up a rebuilt carb for it because the original was a rust ball inside. it was running good until our fall show when it started backfiring every time you open the throttle above an idle. i have been told everything from stuck valves to a cracked manifold to a problem with the governor.has anyone had this problem?can you tell me where i should look first?this tractor came from a locomotive factory in NY. it doesn't seem to have a lot of hours on it.
Old 10-13-2011, 07:58:25 PM
i work for a gas distributer and have only run non eth fuel in her.so i'm sure it's not fuel.i've tried the wd 40 trick no difference.choke on just kills the engine.i wondered about wires i bought all the tune up parts from tractor supply. not real happy with quality.cap is clean underneath.no carbon to speak of.
Old 10-14-2011, 07:58:32 AM
Nebraska Cowman's Avatar
Nebraska Cowman Nebraska Cowman is offline
It's not the governor. It's most likely either spark or fuel. Too rich a fuel mixture or poor spark causing unburnt fuel to be in the cylinder on the exhaust stroke where it ignites causing the backfiring.
The Following User Says Thank You to Nebraska Cowman For This Post:
Old 11-02-2011, 06:27:21 AM
Default Re: International Harvester I4 Help
just wanted to say thanx for all the advice.put on a set of solid core wires seems to run alot better.gonna change the plugs again i think maybe i got a bad set.they were black as coal.my buddy says they werent firing hot enough to burn all the fuel.
Old 11-02-2011, 09:20:11 AM
K D Redd K D Redd is offline
Might also be a bad condenser.
Kent
Old 11-02-2011, 05:55:43 PM
kent i wondered about the condenser i didn't change it when i tuned it up.you have to pull the mag to get it out.and i didn't want to go thru the hassle.
International Harvester UD9 help aloris Multi-Cylinder Stationary Gasoline Engines and Power Units 32 04-21-2019 04:06:51 PM
International Harvester 1/5 or 3 hp 60case Antique Gas Engine Discussion 2 08-26-2009 03:44:25 PM
International Harvester LA Billy Boone Antique Gas Engine Discussion 5 07-28-2007 06:18:52 PM
Re:International Harvester help Tom Marshall Jr. Antique Engine Archives 1 12-19-2003 10:09:44 PM
International Harvester LB 1 1/2- 2 1/2 Chad Schlifke Antique Engine Archives 1 12-19-2003 01:17:29 AM
