Diode Specs
this thread has 10 replies and has been viewed 3111 times
Old 10-15-2011, 01:10:31 PM
David K David K is offline
Default Diode Specs
I'm trying to find the specs on a CR38148 diode. I Google'd "diode cr38148" & "cr38148" and didn't find anything. Does anybody know the specs on this diode or where I can find it? Thanks.
Dave
Old 10-15-2011, 01:35:38 PM
Fred M. Fred M. is offline
Default Re: diode specs
David-
There may be more than one diode with the same part number. It would be helpful to know what it is used in.
I Googled 38148 diode. Does it look like the CR3814800 at the bottom of this page?
http://www.pecrectifier.com/semiconductors.html
I also found CR38148 mentioned with no specs at
http://www.industrialsemi.com/invent...tter=C&page=12
Fred
Old 10-15-2011, 07:58:04 PM
K D Redd K D Redd is offline
NOT to ask a stupid question BUT is this CR38148 on the old diode you have or is this number on the circuit board by the diode. If this number is on the circuit board, This number is it's circuit reference designator NOT the diode's Part Number. Most circuit board mark diodes as CR and then a number. Sometime CR is even used for Zener diodes but sometimes ZD is used for zener diodes.
Kent
The Following User Says Thank You to K D Redd For This Post:
Old 10-15-2011, 10:05:34 PM
Arkie Arkie is offline
And sometimes GE, Motorola, etc, use their own numbers on diodes, and transistors and you cannot cross refernce such! They make the diodes etc, in bulk and sell to companys that assemble the control equipment.
(and 5 numbers is not normal for a diode, normally only 4)
If you don't see it at mouser, Digitech or Allied it's most likely you won't find any specs.
What kind of equipment is it used in or do you know that input volts and output loading???
Old 10-16-2011, 07:35:22 AM
armandh armandh is offline
modern diodes are easy to substitute
diodes have a current rating [A]
this rating should be higher than any expected current or protective fuze
diodes have a peak inverse voltage rating [piv]
this rating should be higher than any ac peak [not RMS] voltage
exceeding these ratings is not harmful given space and cost considerations
using a 10 A @ 200 Volts where you only needed a 5 A @ 100 will likely work just fine
huge over rating is expensive, wont fit, and may involve other problems.
it easiest to use diodes in a similar package [axial, bridge package, etc]
Old 10-16-2011, 09:44:14 PM
Yes, it does. Is it safe to say that CR38148 and CR3814800 are the same? And that CR38148's are 300A and 600V?
To all those who asked.... I'm not looking for a CR38148. Instead I found a bunch of them at surplus price. I was going to buy some of them for future projects or maybe I'll buy all of them and try to make a buck or two on ebay. What do these things go for new?
Dave
Old 10-16-2011, 09:53:57 PM
Default Re: Diode Specs
added picture
Old 10-17-2011, 06:04:54 AM
You could compare prices using the 300amp at 600 piv specs at the vendors I named above!
Hobbiest that are into DC welders, and those would be great as a replacement for the diodes in the large automotive battery chargers, type chargers for starting vechicles. Also if they are all same polarity they would not sell as good. (all common Anode or Common cathode) If some are Reversed polarity they are more user friendly. I've also used the high amperage silcon diodes (usually in the 100amp @ 100 PIV range) as replacements in the old style automotive variable switch output selectable charge rate battery chargers that used the old obselete selenium rectifiers. I would have to shop and get them as surplus to keep the price down with-in reason.
Sometimes the large diodes don't sell very fast in large amounts! You can find similiar on e-bay and watch and see a selling/buying price!
Old 10-17-2011, 08:28:47 AM
NTE6356 cathode to case and NTE6357 anode to case 300 Amp/600Prv. NTE 6102 cathode/NTE6103 Anode 550 Amp/600Prv. Both have 3/4 inch by 16 tpi studs.
Kent
Old 10-20-2011, 11:35:29 PM
Motorwinder Motorwinder is offline
http://www.galco.com/scripts/cgiip.e...um=CR38148-NBR
Old 10-21-2011, 11:30:10 AM
I followed that link, which led to Process Electronics company, which is the PEC link (http://www.pecrectifier.com/semiconductors.html). I could not find any specifications other than the basic voltage and current.
They might not be the original manufacturer. It could be a rebranded part from some other power rectifier company like International Rectifier.
There should be a diode symbol on the body to indicate polarity. Note that the same number with an R0 suffix is the reverse diode. If you obtain them from a surplus electronics source, there might be a mixture of polarity in any given batch.
Fred
Onan BF 3CR diode part# aly9222 Onan Generators 4 09-10-2011 08:21:08 PM
McCulloch/Jenn Feng Generator diode JBittnerSr Generators & Electric Motors General Discussion 1 07-18-2011 06:53:59 AM
Three phase through diode pack to power electric car Walt Military MEP and Aircraft Gen-Sets 3 09-30-2008 06:24:01 PM
MEP-16A Rotating Diode? K D Redd Military MEP and Aircraft Gen-Sets 3 08-19-2008 12:19:28 AM
Field Flash Diode GlobalEnergies Onan Generators 1 03-15-2007 09:00:49 PM
