Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Gasoline Engines and Power Units
Multi-Cylinder Stationary Gasoline Engines and Power Units Waukesha, Buda, Climax, LeRoi and others.
LeRoi mounted pump?
this thread has 0 replies and has been viewed 1484 times
Old 01-06-2012, 02:26:17 PM
Paso One Paso One is offline
Default LeRoi mounted pump?
I 'm not sure where I should ask this question. The trash pump that was mounted to the leRoi engine has a lever that is inside the pump and freely moves back and forth.
Is this lever part of a flapper or is it inside just to catch any grass type trash??
It seems to have a set of screws that might hold something else?? maybea flapper to hold water back to improve priming?? anyone have any ideas?
Name:	058 (Small).JPG
ID:	125167   Click image for larger version
Name:	059 (Small).JPG
LeRoi D201 Pump Engine Paso One Multi-Cylinder Stationary Gasoline Engines and Power Units 13 01-02-2012 01:52:56 PM
LeRoi engine/Domestic pump Clark Bigger Multi-Cylinder Stationary Gasoline Engines and Power Units 10 10-09-2009 10:50:04 PM
Waterloo mounted pump jacks? Kevin O. Pulver Hit & Miss Gas Engine Discussion 0 10-11-2008 12:48:12 PM
Early Wall Mounted Water Pump K.Watkins Farm Antiques and Collectibles 3 05-30-2007 09:46:32 AM
Hydraulic Pump Mounted To Farmall A Power Takeoff Linda Antique Farm Tractors 3 12-16-2005 05:17:46 PM
