Steam Engines
Antique Vertical Steam Engine
this thread has 23 replies and has been viewed 2611 times
Old 10-11-2017, 03:31:05 PM
badboy1950 badboy1950 is offline
Photo Antique Vertical Steam Engine
i visited with a fellow club member this morning to see if he had an engine that would fit an economy tractor i am about to work on.
we looked through his collection in the garage, storage trailers and a few sheds but found nothing that would fit.
as we were walking and talking i mentioned that i am machining and assembling a Stuart steam engine model.
he said he had a small steam engine in one of the sheds and would i like to take a look at it.
yes i would .... fast forward, i have the engine on my bench and took these photos.
a google search of J C Moody Boston which is on the tag brought up nothing, also searched antique steam engine Moody on google and here with no results yet.
has anyone seen another like this ?
is this engine a one off built by moody ?
your thoughts or info would be appreciated.
Dan
ID:	293308   Click image for larger version
ID:	293309   Click image for larger version
ID:	293310   Click image for larger version
The Following 7 Users Say Thank You to badboy1950 For This Post:
Old 10-11-2017, 03:41:06 PM
Default Re: antique vertical steam engine
the flywheel is 7" and the crankshaft is 15 " long.
everything moves freely and smooth by hand.
ID:	293312   Click image for larger version
The Following 3 Users Say Thank You to badboy1950 For This Post:
Old 10-11-2017, 07:08:04 PM
al vanley al vanley is offline
The riding cut off seems unusual for an engine of that size. Guessing it was manufactured for some commercial use, maybe jewellery manufacture or industrial sewing operation. The Pumphouse Museum in Kingston, Ontario, has several engines of similar size used to run industrial sewing machines. Anyway, very nice find, thanks for posting it.
Al
The Following 2 Users Say Thank You to al vanley For This Post:
Old 10-11-2017, 10:55:12 PM
cyberbadger cyberbadger is offline
Default Re: Antique Vertical Steam Engine
To my eyes it looks suitable for a small steam launch.
-CB
The Following User Says Thank You to cyberbadger For This Post:
Old 10-12-2017, 05:51:31 PM
i oiled it last night and ran it on 20 lbs. of air, it runs smooth.
Al what do you mean by riding cutoff as i am new to the world of steam.
what are those two pumps running of the single eccentric do ?
Dan
The Following User Says Thank You to badboy1950 For This Post:
Old 10-12-2017, 11:55:58 PM
reubenT reubenT is offline
one pump might be for boiler feedwater, don't know why 2. The extra eccentric running a cutoff valve would help the engine run more efficiently. But makers and users of small engines were not usually too concerned about maximum efficiency. The cutoff valve on the larger engines would be adjustable by hand crank or governor controlled, to vary the degree of cutoff based on load requirements. Many different versions were tried. The corliss rocker valve design was a popular variable cutoff design fully governor controlled. I have reprints of old books with detailed drawings of a number of different valve actions. Interesting engine anyway. I know there were quite a few small scale makers that got lost in history. Although ACME was not too small of a manufacturer I have an ACME built engine of westinghouse design that seems pretty rare. A vertical 2 cylinder single acting "high speed" engine. Hunting the internet I've only been able to find one other of it's kind and it had a different valve action.
The Following User Says Thank You to reubenT For This Post:
Old 10-13-2017, 08:10:02 AM
Dale Miner Dale Miner is offline
Dan
Is it possible the larger pump was a vacuum pump to enable running condensed?
The Following 3 Users Say Thank You to Dale Miner For This Post:
Old 10-13-2017, 09:09:38 AM
Dale , what is running condensed ?
Dan
The Following 2 Users Say Thank You to badboy1950 For This Post:
Old 10-13-2017, 10:39:22 AM
Grape Grape is offline
Images: 12
I'm not the most experienced person on steam engines but I'm learning. Cutoff is the point where the valve opens or closes to push steam into the cylinder. This allows the governor or operator to use the smallest amount of steam per stroke of the piston and still get the necessary power.
I also believe what Dale means by running condensed is re-using the water that condenses from the steam during operation. (but don't take that as gospel)
Phil Grape
Remember, to Belittle others is to Be Little yourself
The Following User Says Thank You to Grape For This Post:
Old 10-13-2017, 05:48:21 PM
Joe K Joe K is offline
Al
It may not be riding cutoff. Usually riding cutoff engines have some way to adjust the "rider" and thereby affect admission (or other events of the stroke.)
The original riding cutoffs usually had a handwheel on the head (or nearby) and right/left threads on the valve stem such that turning the wheel affects both riders equally in their effect on the admission.
It may simply be "separated" valve action between upper cylinder and lower cylinder. A way to compensate for "angularity of the connecting rod" (which in valve setting is usual to hit a mid-point with neither head nor crank end exactly optimal but both "near optimal") and a way to fine tune both when separated.
Opening the valve chest should reveal all.
Joe in NH
The Following 5 Users Say Thank You to Joe K For This Post:
Antique vertical (Stuart) engine nar Scale Model Engineering 6 03-04-2017 06:02:07 PM
Vertical Steam Engine ? another one fallenlodge Unidentified Engines 2 12-19-2016 04:54:58 AM
Troy Steam Engine Circa 1910 Vertical Self Oiling Steam Engine Restoration Thread. ficord Steam Stationary Engines, Traction Engines, Steam Boats 73 12-09-2016 11:30:47 AM
vertical steam engine help Tim Rostar Steam Stationary Engines, Traction Engines, Steam Boats 7 10-15-2009 09:49:58 AM
New Vertical Steam Engine kmv Vintage Toy Steam Engines and Motors 0 10-14-2008 11:35:17 AM
