Steam Engines
Riveted Steam, Water, Boiler Tank, I Dont Know
this thread has 24 replies and has been viewed 2284 times
Old 06-06-2018, 12:34:07 PM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
Photo Riveted Steam, Water, Boiler Tank, I Dont Know
Got this recently but not sure what type of tank or its application Theres also a threaded hole in the bottom same size as the others. The tank had been stored in the basement of a business building built in the 1890's.
Patrick
ID:	311956   Click image for larger version
ID:	311957   Click image for larger version
ID:	311958   Click image for larger version
Old 06-06-2018, 12:35:54 PM
Default Re: Riveted Steam, Water, Boiler Tank, I Dont Know
One more.....
Patrick
Old 06-06-2018, 01:00:30 PM
Casemaker Casemaker is offline
Call the company up and ask them..https://aymcdonald.com
Old 06-06-2018, 01:09:07 PM
It is a water tank. It goes in the attic of a house for a pressure system.
The Following 2 Users Say Thank You to Bill Hazzard For This Post:
Old 06-06-2018, 01:55:02 PM
Heins Heins is offline
A lot of water tanks were riveted before they welded later tanks, some weren't even pressure tanks.
Old 06-06-2018, 02:49:07 PM
LCJudge LCJudge is offline
Most of those had the top 1/4 with an air chamber. The tank would fill at the bottom and the air chamber on top would build up 30 to 35 psi. This pressure would then force feed the water to the entire house. Most all the tanks made before the mid 1920ís were riveted. Then they were a combination of riveted and welded and eventually just welded.
Tommy Turner
The Following 3 Users Say Thank You to LCJudge For This Post:
Old 06-06-2018, 03:57:24 PM
Doug Wilson Doug Wilson is offline
That's the nicest tank from that era ive ever seen. Good score.
The Following User Says Thank You to Doug Wilson For This Post:
Old 06-06-2018, 05:20:55 PM
Vanman Vanman is offline
I have one of these that someone cut a section out of and welded it back together to make it smaller.
Then they built an air compressor out of it!
Needless to say I removed it from air compressor service.
Old 06-06-2018, 07:35:49 PM
jack0 jack0 is offline
Looks like a range boiler.
Side taps for thermo-siphoning.
cold water dip tube and hot water out.
The Following 2 Users Say Thank You to jack0 For This Post:
Old 06-06-2018, 10:02:35 PM
Jeff Dudgeon Jeff Dudgeon is offline
I agree, it looks like a water heater. A lot of the early ones would not be insulted.
Cahall water tube steam boiler (1897) TractorDom Steam Stationary Engines, Traction Engines, Steam Boats 1 11-20-2015 12:02:25 AM
Old Wall Quincy compressor, electro brazed & riveted tank mschreiber Farm + Industrial Antiques and Collectibles 9 03-08-2014 10:54:51 PM
Whats the name of the steam tractor that uses a water tube boiler Daniel Craig Steam Stationary Engines, Traction Engines, Steam Boats 13 10-02-2012 12:52:41 AM
converting a hot water tank or air compresser into a boiler steampower88 Steam Stationary Engines, Traction Engines, Steam Boats 61 08-31-2012 06:34:52 PM
Vertical Riveted Steam Boiler Nik O. Steam Stationary Engines, Traction Engines, Steam Boats 4 03-14-2010 05:21:40 PM
