Steam Engines
Riveted Steam, Water, Boiler Tank, I Dont Know
this thread has 24 replies and has been viewed 2396 times
Old 06-07-2018, 12:27:15 AM
chrsbrbnk chrsbrbnk is offline
Default Re: Riveted Steam, Water, Boiler Tank, I Dont Know
I like the air compressor idea put a good air tank inside hide the surgery and scare the @#$ out of every one!
The Following User Says Thank You to chrsbrbnk For This Post:
Old 06-07-2018, 07:39:03 AM
DianneB DianneB is offline
Originally Posted by Vanman View Post
Then they built an air compressor out of it!
Needless to say I removed it from air compressor service.
I saw one like that but bigger and the idiot owners (at an airport) were going to use it for air. They had it out on the grass beside the building and were pumping it up with air to "test" it - I made rapid tracks far away!!! The base seam split, the tank went like a rocket and did MAJOR damage to TWO aircraft on the ramp. They should have listened to the girl who tried to warn them
The Following 3 Users Say Thank You to DianneB For This Post:
Old 06-07-2018, 10:11:24 AM
Joe K Joe K is offline
I like the range boiler idea - that was my first impression.
But were not most of these copper or bronze? Galvanized it might be in the cheaper versions.
Joe K
Old 06-07-2018, 07:16:40 PM
steamsatisfies steamsatisfies is offline
Joe, the ones that I hav seen were galvanized. They usually stood next to the range on a cast iron stand that was 18 to 24" in height. Some of the stands were kind of ornate.
Old 06-07-2018, 09:38:42 PM
Dale Miner Dale Miner is offline
Definately water storage. It is galvanized, probably hot dipped after being riveted from the size of the spangle.
Old 06-10-2018, 05:00:28 PM
Jim Conte's Avatar
Jim Conte Jim Conte is offline
Images: 2
It would make a great stand for a mailbox, or a flower planter. Use it for anything Except pressure
http://www.boilersaver.com/
Old 06-10-2018, 05:18:37 PM
Vanman Vanman is offline
Water pressure would be fine, like a hot water tank, just not air or steam.
Old 06-11-2018, 10:20:00 PM
BoilerGuy BoilerGuy is offline
after reading this post a week or so back, I was reminded of it Saturday. I was on Mackinaw Island touring the Fort and came across this in the Fort Bath House.
The Following 7 Users Say Thank You to BoilerGuy For This Post:
Old 06-12-2018, 09:44:04 PM
DCamp DCamp is offline
I use one hooked to my wood furnace to preheat water before it goes into the regular tank. Saves a lot on the electric bill.
The Following User Says Thank You to DCamp For This Post:
Old 06-13-2018, 01:38:39 AM
I always wondered how the water temperature was regulated with these? What keeps them from becoming a boiler?
Cahall water tube steam boiler (1897) TractorDom Steam Stationary Engines, Traction Engines, Steam Boats 1 11-20-2015 12:02:25 AM
Old Wall Quincy compressor, electro brazed & riveted tank mschreiber Farm + Industrial Antiques and Collectibles 9 03-08-2014 10:54:51 PM
Whats the name of the steam tractor that uses a water tube boiler Daniel Craig Steam Stationary Engines, Traction Engines, Steam Boats 13 10-02-2012 12:52:41 AM
converting a hot water tank or air compresser into a boiler steampower88 Steam Stationary Engines, Traction Engines, Steam Boats 61 08-31-2012 06:34:52 PM
Vertical Riveted Steam Boiler Nik O. Steam Stationary Engines, Traction Engines, Steam Boats 4 03-14-2010 05:21:40 PM
