Steam Engines
Rebuilding Marsh Steam Pump
this thread has 23 replies and has been viewed 1421 times
Old 06-18-2018, 09:42:27 PM
PFT's Avatar
PFT PFT is offline
Images: 31
Default Re: Rebuilding Marsh Steam Pump
Welcome to the Stak Sid. Just out of curiosity, where in Skaneateles are you from? Until last June I lived in Marietta over looking the north end of Otisco Lake. Too bad you didn't join up a few years ago, we could have met up and talked old iron.
P. Thompson
Old 06-19-2018, 09:44:14 AM
Sid Pileski Sid Pileski is offline
P. Thompson
I'm on Eibert Rd. Between Otisco and Skaneateles lake. Just a stone throw away!
---------- Post added at 09:44:14 AM ---------- Previous post was at 09:41:12 AM ----------
I'd also appreciate any input for the choice of the gland packing material.
McMaster-Carr has a lot to choose from. What do you recommend as far as material and diameter?
I was thinking their PTFE 3/32 material???
Thanks, Sid
Old 06-25-2018, 10:59:02 AM
Well, the Marsh is up and running. It actually runs on air quite well with very low pressure.
As far as the pump side, it seemed to have suction (not a lot) when I put my palm over the intake.
I gave it back to the fellow I was getting it running for, and he was going to hook up the water tubing.
Is this pump designed/expected to draw the water from much distance below the pump?
Thanks, Sid
The Following User Says Thank You to Sid Pileski For This Post:
  #24
Old 06-28-2018, 03:51:40 PM
Steve Kunz's Avatar
[QUOTE=Brad Kelley;
My Marsh "B" quit running this April at steam school[/QUOTE]
Brad, I see your pump says American steam pump co.Battle Creek Michigan on the side. Does it say anything on the air chamber?
Mine says, Battle Creek steam pump co. Battle Creek Michigan. My air chamber says something? Steam Pump but I can't make it out.
The piston has a bunch of discs stacked up. They are pretty thin and kind of a cross between rubber and leather material.
ID:	313223   Click image for larger version
ID:	313224   Click image for larger version
Steve Kunz
Marsh Simplex Steam Pump Troubles. JBoogie Steam Stationary Engines, Traction Engines, Steam Boats 29 08-26-2013 04:30:59 PM
Marsh Steam Pump Winans Steam Stationary Engines, Traction Engines, Steam Boats 8 03-25-2013 09:07:09 PM
Marsh steam pump, operating question Brad Kelley Steam Stationary Engines, Traction Engines, Steam Boats 26 12-26-2006 06:11:17 PM
Marsh steam pump off Case Casemaker Steam Stationary Engines, Traction Engines, Steam Boats 17 06-09-2006 12:52:59 AM
Marsh Steam Pump help Dan Donaldson Steam Stationary Engines, Traction Engines, Steam Boats 5 04-04-2006 10:09:12 AM
