Steam Engines
Huber Traction Engine
this thread has 11 replies and has been viewed 1341 times
Old 06-20-2018, 07:26:55 AM
Woody2956 Woody2956 is offline
Default Huber Traction Engine
Hello all, I am just beginning to restore a 1930 16hp traction engine that has been in storage for 63 years. My questions are 1. was gloss paint used? 2. were they brushed or sprayed?
There are many places that the original paint is still there but it appears to be flat but I'd like some opinions. In addition this machine came with many original patterns such as , grates, fly wheel, ash pan and others. I am having a set of grates cast for myself and if anyone is in need let me know. Thanks all....Woody
The Following 4 Users Say Thank You to Woody2956 For This Post:
Old 06-20-2018, 08:59:47 AM
Farquharman Farquharman is offline
Default Re: Huber traction engine
Welcome aboard! Have you contacted the Huber Museum folks over in Marion, they might be able to tell you for sure. I would think flat paint but that is just a guess on my part. Good luck on your restoration and please post pictures here!
Old 06-20-2018, 01:04:00 PM
Images: 2716
A couple of photos of Huber engines on RR flatcars, outbound of the factory. Gary
Name:	A New Huber return flue engine on Railroad RR flatcar Mark C.jpg
ID:	312768   Click image for larger version
Name:	Huber factorn engines threshers on RR cars..jpg
The Following 7 Users Say Thank You to 20 Reeves Highwheeler For This Post:
Old 06-20-2018, 05:34:11 PM
Steve Kunz's Avatar
Hi Gary, I noticed on your second picture the first engine has the flywheel on the left and the second two engines have the flywheel on the right. I wonder what the difference is?
Steve Kunz
Old 06-20-2018, 05:41:20 PM
Gary Jones Gary Jones is offline
Hi,
Just a guess but I'll bet an old left flywheel model was in for a rebuild and being sent out to an agent with a shipment of new ones.
Best wishes to all,
Gary Jones
The Following 2 Users Say Thank You to Gary Jones For This Post:
Old 06-20-2018, 09:32:00 PM
Images: 2716
Like Gary Jones stated, it may have been an old one in for a rebuild? Or it could have been one that set for a while and finally sold. I dunno?!
PS: Lyle Hoffmaster told me that his friend Glen Kuhn(?, a Reeves employee) said there were engines in the back lot and in the big shed that never sold and were even scrapped, as brand new engines. However, that would have been Emerson & Brantingham who did that with those engines.
The Following User Says Thank You to 20 Reeves Highwheeler For This Post:
Old 06-20-2018, 10:26:36 PM
20advance 20advance is offline
Default Re: Huber Traction Engine
Do you have the serial number? Wonder if it is close to ours?
20advance
Old 06-23-2018, 06:33:39 AM
Huber4062 Huber4062 is offline
When I removed my blanket off of my boiler for inspection it appeared to be a gloss/semi gloss paint on the boiler. But I suppose it’s possible that it may have been the sap from the wood baked on?
If I were painting mine today I’d go semi gloss, but could change my mind by the time I actually get around to paint.
Old 06-23-2018, 08:58:23 AM
David Babcock David Babcock is offline
Question Re: Huber Traction Engine
I think the flywheel question may be that the negative was developed backwards. Db.
Old 06-23-2018, 09:25:24 AM
GreasyIron GreasyIron is offline
The head tank print and background print look right, so I'd say just the front one with left flywheel rather than the other way around.
....Woody
Woody,
You may have posted about this engine before, so I apologize in advance if I missed it. But have you given the boiler a good inspection? I've no reason to think not, but with this thread being about paint, I thought a good question to ask before things are prettied up, then steel needs to be replaced.
Good luck!
The Following User Says Thank You to GreasyIron For This Post:
1881 Traction Engine Trial-Geiser, Frick & Huber Mike McKnight Steam Stationary Engines, Traction Engines, Steam Boats 13 08-25-2016 09:42:51 AM
Small Traction Engine-Little Engineer-BIG Project! 12 HP Huber Mike McKnight Steam Stationary Engines, Traction Engines, Steam Boats 15 12-22-2013 11:07:50 AM
Huber steam traction engine what kind? danathetractorbarn Steam Stationary Engines, Traction Engines, Steam Boats 24 08-10-2013 07:22:16 AM
Huber Traction Engine 6hp Jeff Smith Steam Stationary Engines, Traction Engines, Steam Boats 24 09-23-2011 09:45:30 PM
Huber Steam engine & Huber Tractor to be Auction Nov 7th roebersauctions Live Auctions of Engines, Tractors and Old Iron 16 11-10-2009 10:40:19 PM
