Steam Engines
Boiler Explosion
this thread has 15 replies and has been viewed 2200 times
Old 06-27-2018, 07:43:56 AM
AussieIron AussieIron is offline
Default Boiler Explosion
Saw this at a small museum recently in North Queensland Australia.
Sorry, no details were available, but must have gone off with quite a bang!
Don't know much about steam, but thought you might be interested.-Cheers -Neil.
ID:	313114   Click image for larger version
ID:	313115   Click image for larger version
Old 06-27-2018, 08:04:32 AM
Odin Odin is offline
Default Re: Boiler Explosion
First guess on what happened to it would be low water- the crown sheet blew out.
Usually that turns the boiler into a rocket, tumbling end over until it runs out of steam. Even some of the world's largest locomotives had that happen to them.
Old 06-27-2018, 08:15:32 AM
Big Bird Big Bird is offline
Boiler ... May Need some work... Possibly needs some tubes replaced. Was running great just before the picture was taken.
The Following 8 Users Say Thank You to Big Bird For This Post:
Old 06-27-2018, 10:37:12 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
The volume of water that those big engines consume, it don't take long to get into trouble if anything happens to the feed water delivery.
The Following 2 Users Say Thank You to FWurth For This Post:
Old 06-27-2018, 01:12:27 PM
Unhappy Re: Boiler Explosion
I have a book on railroad accidents, and one whole chapter is on boiler explosions. Most are fault of the crew, for letting the water get to low. A few are material failure - excess pressure against a weak point. The power of steam released in a boiler failure is tremendous. It can blow a 96000 pound loco clean off the tracks, often many feet into the air and hundreds of feet away. Others completely destroy the loco and anything around it. There was such a blast in Texas - I believe in 1912, that blew a 1600 pound chunk over a 1/4 mile from the engine. The engine had been just repaired, and the crew was setting the blow off valve when the engine blew. The work house was destroyed along with many other engines, and it killed 22 people. A 900 pound chunk of the boiler went about 1/2 a mile, and destroyed a farm house.
Old 06-27-2018, 11:52:38 PM
halcon halcon is offline
I have the same book, it seems commonly that the crew either dosed off or sometimes were into the spirits which was common back in that day, then when't passed a water stop and tried to make the next one. Some times the disaster occured while in front of that second water tower. Long hours on a locomotive can cause drousyness same as driving a road vehicle.
Old 06-28-2018, 06:14:51 AM
woodyarmourer woodyarmourer is offline
Thats the one at herberton.
I'll try to dig up the history, but i think it was a locomotive.
The Following 2 Users Say Thank You to woodyarmourer For This Post:
Old 06-28-2018, 08:38:12 AM
I don't remember off the top of my head what sort of problem it is that causes the superheater tubes to be ejected like that. But I do know that's what happened in pictures like this, something happened inside the locomotive that caused the superheater tubes to be spat out. Most of the flues are still in the boiler, ruptured or not, and that tangle of piping is superheater tubes and accessories.
Google says that engine is C&O class T-1 #3020, May 12th 1948. When I have more time I'll see if I can find a description of what happened.
Old 06-28-2018, 09:34:42 AM
typak typak is offline
Some details...
ID:	313181   Click image for larger version
The Following 2 Users Say Thank You to typak For This Post:
Old 06-28-2018, 09:38:11 AM
Jasen Jasen is offline
Here is a link to the 1912 Texas explosion.
http://colfa.utsa.edu/users/jreynolds/Tucker/exp1.html
The Following 5 Users Say Thank You to Jasen For This Post:
4/3/17 - Boiler Explosion in St Louis DustyBar Steam Stationary Engines, Traction Engines, Steam Boats 31 04-12-2017 09:08:05 AM
1897 Boiler explosion Steamrguy Steam Stationary Engines, Traction Engines, Steam Boats 1 07-16-2009 01:29:45 AM
Mitchell, SD boiler explosion Gary K Steam Stationary Engines, Traction Engines, Steam Boats 91 04-14-2006 01:11:21 AM
Boiler explosion Andre' Blanchard Steam Stationary Engines, Traction Engines, Steam Boats 2 01-02-2004 12:08:34 AM
110 Case Boiler Explosion Smitty Antique Engine Archives 0 08-18-2001 11:50:57 PM
