Steam Engines
Steel Wheel Identification Help Please
this thread has 10 replies and has been viewed 874 times
Old 07-09-2018, 01:01:55 PM
blacklockfarms blacklockfarms is offline
Default Steel Wheel Identification Help Please
I purchased a sorghum mill at and auction over the weekend the auction had a traction engine as well as lots of other steam engine related things. A guy at the auction thought this sorghum mill was sitting on a traction engine wheels and axle they are mounted to an old truck frame. I plan to take them out from under it just curious as to what they belong to maybe even a manure spreader or something just thought it would be fun to know what they came off of. They are roughly 40inches tall and 7.5 inches wide
ID:	313924   Click image for larger version
ID:	313925   Click image for larger version
ID:	313926   Click image for larger version
The Following User Says Thank You to blacklockfarms For This Post:
Old 07-09-2018, 02:14:09 PM
FRICKnHUBER FRICKnHUBER is offline
Default Re: Steel wheel identification help please.
Enterprise?
Old 07-09-2018, 06:17:38 PM
Thresherman Thresherman is offline
Default Re: Steel Wheel Identification Help Please
What did keck go for..condition?
Old 07-09-2018, 07:53:19 PM
LeRoy IHC LeRoy IHC is offline
Card Sponsor
Hello
Any chance you can see a part number on the hub. Number should be located in the groove that goes around the hub. I'm betting if the wheels are 44 inches in diameter they fit a 25 Hp. Type C Mogul. If they are 38 inches in diameter 20 Hp. Type B tractor, if here 36 inches in diameter they go on a 20 Hp. Type C Mogul
Let us know what you find out.
LeRoy
The Following User Says Thank You to LeRoy IHC For This Post:
Old 07-09-2018, 10:29:27 PM
anthony k axsom anthony k axsom is offline
$16,400.00 Sold KG engine
The Following User Says Thank You to anthony k axsom For This Post:
Old 07-10-2018, 02:00:51 AM
Originally Posted by LeRoy IHC View Post
Hello
LeRoy
I'll check in the morning for part numbers there appreciate the reply
Old 07-10-2018, 12:45:06 PM
KGC1615's Avatar
KGC1615 KGC1615 is offline
Boiler was thin. .224, .228 all over below the water line, crown and side sheets the same. Stays had about 1/3 wasting at the base.
Tom
"Those are my principles, and if you don't like them... I have others." Groucho Marx
The Following 2 Users Say Thank You to KGC1615 For This Post:
Old 07-10-2018, 05:59:11 PM
Larry G. Larry G. is offline
KGC1615,Those aren't ideal readings on boiler plate but you and I have seen worse ones. Dee Quick's Keck was .125 around the front pedestal part of the boiler. The state of Illinois allowed 110 psi MAWP on that one. GO figure! Dee fired his engine on that amount of pressure for years and he was satisfied with it. Dee was one of my mentors and he knew what live steam would do to you if you were careless. :eek Back to the title,I wonder if there was an IHC Mogul on this farm.
Larry G.
The Following User Says Thank You to Larry G. For This Post:
Old 07-10-2018, 07:58:52 PM
From the pictures I've found online it sure does appear these would belong to one of the monguls. Would these be worth anything other than scrap? I would never scrap them but would be interested In putting them in someone who appreciates them hands. A fellow at the auction has first chance at them anyhow I was just curious as to what they belonged to I sure appreciate the help.
Old 07-10-2018, 08:24:12 PM
KGC1615's Avatar
Larry, a family member said they did do a hydro to 175 lbs. a while back without any problems, so......... go figure!
Tom
The Following User Says Thank You to KGC1615 For This Post:
Steel wheel identification and questions Mrnick Antique Gas Engine Discussion 8 06-03-2017 09:01:26 PM
Steel Wheel Identification ? Greg Mosley Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 12-19-2015 01:34:07 AM
steel wheel case identification Prewar Engines Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 04-17-2015 02:54:28 PM
Steel Wheel identification weathervaneman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 11 09-25-2011 11:20:53 PM
Big steel wheel what should I do with it. Chances R Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 18 03-24-2009 03:26:23 PM
