Steam Engines
32 Reeves Engine on 40 hp Reeves Boiler
this thread has 47 replies and has been viewed 9749 times
Old 05-19-2018, 05:59:42 PM
Default Re: 32 Reeves engine on 40 hp Reeves Boiler
I saw the boiler drawings today that were submitted to Alberta boiler branch in 1912. The 32hp simple and 40 compound Canadian Special are the same boiler. The drwg is listed as 32 simple/ 40 compound .
The Following 4 Users Say Thank You to David Hoover For This Post:
Old 05-19-2018, 06:47:14 PM
Images: 2716
Default Re: 32 Reeves Engine on 40 hp Reeves Boiler
David, They are the same basic boiler. They would be like this boiler below. The differences would be where the indentations for the upper cannon bearing would go, as the gearing and driver wheels are of different diameter between the two engines. I was told by old timers the fireboxes were a smidgeon taller on the 40 hp. To accommodate differences in gearing and wheel diameters. I guess a tape measure and being at the right locations could settle that?
This is the Kolar 32-120 hp Reeves double simple here in Montana.
This is 40-140 hp Reeves now at Osage, Iowa, for comparison. This was taken at Cedar Falls in 1992. Gary
The Following 11 Users Say Thank You to 20 Reeves Highwheeler For This Post:
  #43
Old 05-20-2018, 02:57:23 PM
Tim Colwell's Avatar
Tim Colwell Tim Colwell is offline
Call up Larson welding. There's a 32 DS there right now and a 40 hp boiler. This argument can be settlled once and for all.
Tim Colwell
JD & IHC corn sheller and engine collector.
The Following 4 Users Say Thank You to Tim Colwell For This Post:
  #44
Old 05-20-2018, 03:06:56 PM
Images: 2716
Tim, I would still wonder if the US and the Canadian 32 hp double simple arrangements were the same? The US may have the exact dimensions, but I know the barrel is larger on the 32 hp Canadian Special double simple, than the US 32 hp double simple. Gary
The Following User Says Thank You to 20 Reeves Highwheeler For This Post:
  #45
Old 05-20-2018, 05:23:04 PM
MPierce MPierce is offline
Email NOT Working - Over Quota
Yep. US 32, CS 40. Might make a difference. Canadian barrels 2" larger.
Old 06-24-2018, 09:32:01 AM
McDonaldTWB McDonaldTWB is offline
Hi there
can any one help me with info on a 16hp reeves engine # 6713
thank for any info all help
The Following 2 Users Say Thank You to McDonaldTWB For This Post:
  #47
Old 06-24-2018, 10:44:12 AM
Larry G. Larry G. is offline
Congrats,on the purchase of yours Reeves engine. I would suggest that you check the boiler with an ultrasonic tester to know its condition. Your engine looks to be very complete from the auction pictures.
Larry G.
Old 06-28-2018, 10:03:46 PM
Beth V's Avatar
Beth V Beth V is offline
Originally Posted by McDonaldTWB View Post
Hi there
Congratulations on your purchase. Check out this thread: https://www.smokstak.com/forum/showthread.php?t=66137
Cameron Ranch 40 HP Reeves, 4-110 Cases, 1-30 Hp Rumely, 1-32 Hp Reeves and ? Randy Kvill Steam Stationary Engines, Traction Engines, Steam Boats 35 04-11-2017 11:53:36 PM
Reeves Boiler Drawings vicolive Steam Stationary Engines, Traction Engines, Steam Boats 0 02-11-2016 04:42:56 AM
110 H. P. Reeves Canadian High Pressure Boiler 200 Lbs. kd6kyy Steam Stationary Engines, Traction Engines, Steam Boats 4 01-11-2014 11:24:56 AM
Reeves 20 pulling Reeves No 1 Mill fixyerdigger Steam Stationary Engines, Traction Engines, Steam Boats 2 08-20-2013 10:38:26 PM
Boiler pressure of 20hp cc Reeves needed! benz1890 Steam Stationary Engines, Traction Engines, Steam Boats 34 03-31-2010 03:41:42 AM
