Steam Engines
Keck Gonnerman Q & A
this thread has 1645 replies and has been viewed 239606 times
Old 05-16-2018, 09:06:10 AM
Larry G. Larry G. is offline
Default Re: Keck Gonnerman Q & A
The old thought of " Trial and Error" applies here. I wouldn't remove any material from the valves. Keck set the valve motions at the factory when the engines were new. So you should be able to do it again. Look at another double cylinder Keck to see how the valves are set. BTW your restoration work is top quality.
Larry G.
The Following User Says Thank You to Larry G. For This Post:
Old 05-30-2018, 09:51:23 AM
Found this on auctionzip.com, a 24" Keck Gonnerman threshing machine listed in an auction located at Shipshewana,Indiana on Friday,June 1. Chupp Auctions and Real Estate LLC. It is listed with 8 other threshers. They all look to be in good condition. '' This one looks to be an Indiana Special ". The outside width of the trucks is 6 feet. Folks, if you want a Kay-Gee thresher this one would be a good choice. The auction company states they are going to run them the day before the auction. I'm going to be a salesman for Keck Gonnerman in my next life.
Larry G.
  #1643
Old 06-06-2018, 12:03:59 PM
BakerMaker's Avatar
BakerMaker BakerMaker is offline
Images: 2
As I looked in to this further, I discovered another problem. With the crank at TDC or BDC and the eccentric set at 90 deg., the valve should not move perceptibly when the reverse lever is moved back and forth which should be true for the Miller, Baker or other gears in this class. If everything is set up right, the axis of the end of the eccentric should be lined with the axis of the pivot arm, thus resulting in no movement when the reverse lever is moved. This was not happening on the LH engine and it was off quite a bit. Determined to understand why this and couple of other things that were going on, I modeled the gear in Solidworks as well as a mathematical model in MATLAB. When I first ran the models I was having the same problem, but to a lesser degree. When I built the models, I didn't compensate for the fact that the eccentric is at angle in this condition. I added a bit to the length of the eccentric arm ( only .040" ) to line it with the pivot axis and worked OK then. This was a clue to what was going with the engine. Because of the way the valve gear is constructed, it is difficult to see how the eccentric arm was lining up so I made a tool to check the alignment and found the arm was about 1/8" short. I unbolted the eccentric arm from the eccentric casting and slotted the bolt holes so I could stretch the arm ( someone had already slotted them some before ). I stretched the arm 1/8" and VOILA, everything was copacetic. My first thought was that maybe I moved the crank axis when I rebabbitted the mains. But I went over to the RH cylinder and it was spot on as is! This is typical of the goofy stuff I found that Keck did when they built the engine ( I could fill a book ).
I also noticed other things like the ports opening different distances on the front and back part of the stroke and different distances depending on forward and reverse. The models predicted this quite well and it was confirmed by observation of the real thing. This is inherent in the geometry of the gear and not much you can do about it. However, if you look at a Baker, the belcrank arms are not 90 degrees but at an angle. This would have the effect of lengthening the stroke in one direction and shortening it in the other direction, this correcting somewhat for the asymmetrical front to back port openings. The Keck belcrank arms are at 90 degrees.
So the bottom line is I could have tried until I was blue in the face and it still would have been in error.
I have all sorts of other interesting data and graphs from the models but I won't bore you with the details.
The lead problem is still there with about .050 negative lead ( port closed ). Cutting 1/16" off each end of valve gives about .01 lead which is acceptable. If I screw up I can glue some bronze back on easy enough or cast new valves.
One test is worth a thousand expert opinions - Attributed to Wernher Von Braun
The Following 2 Users Say Thank You to BakerMaker For This Post:
  #1644
Old 07-07-2018, 11:26:10 AM
GreasyIron GreasyIron is offline
Any news on 1623? I think the auction is/was this morning.
Old 07-07-2018, 07:33:47 PM
My informative KGB agent told me that # 1623 is going to stay in Kentucky. It was sold as an operating engine.
Larry G.
  #1646
Old 07-11-2018, 07:25:30 PM
KGC1615's Avatar
KGC1615 KGC1615 is offline
Here is a link to the selling of KGC #1623. It went for $16,600, my mistake.
https://www.facebook.com/haleyauctio...location=group
Tom
"Those are my principles, and if you don't like them... I have others." Groucho Marx
The Following 2 Users Say Thank You to KGC1615 For This Post:
Keck Gonnerman Gas Tractors wayne m. Antique Farm Tractors 24 08-05-2012 12:13:29 PM
Minneapolis & Keck-Gonnerman Mike in NC Steam Stationary Engines, Traction Engines, Steam Boats 26 01-07-2011 03:16:10 PM
A Keck Gonnerman Story KGC1615 Steam Stationary Engines, Traction Engines, Steam Boats 7 02-03-2009 09:27:10 AM
keck gonnerman thresher Wayne Riedlinger Farm + Industrial Antiques and Collectibles 0 07-12-2006 07:58:56 AM
KECK GONNERMAN Ryan J. Shannon Steam Stationary Engines, Traction Engines, Steam Boats 2 08-30-2004 10:20:21 PM
