MM Twin City JTS
this thread has 3 replies and has been viewed 2932 times
Old 05-08-2008, 08:14:53 PM
DavidRaines DavidRaines is offline
Default MM Twin City JTS
While you all were fighting the muck and snow at Le Seuer, I left and went to Watertown driving through snow drifts and picked this up. Am I dumb or what?
This will be my first venture into a tractor restoration. Does anyone know where to find a shop manual and or parts manual for the JTS?
Also need to know where to find an oil filter 'element' and a gasket set. The motor is free but judging from the gunk in the oil filter and the rust inside the block where antifreeze should be, I am going to tear it down.
The governor and carb were frozen up but am making pretty decent headway with them.
Any help appreciated.
Dave
ID:	33440   Click image for larger version
The Following User Says Thank You to DavidRaines For This Post:
Old 05-09-2008, 08:21:43 AM
Default Re: MM Twin City JTS
Jensales has the J service manual, but I don't know if it would be applicable to the JTA. Great looking tractor remains though! Good luck on the restoration.
Old 05-09-2008, 09:15:46 AM
A good looking project! Have seen much worse!
Jensales does have reprints. Manuales and litterature are written up using the row crop because there were only 469 standards made. There is only one very small original advertising leaflet made featuring the JTS.
I have a very nice original manual, a hood and source for oil filter replacement here.
Check with Olsons Gaskets, most of the original or NOS gaskets and engine parts seem to be gone now.
Spend extra time cleaning out rust scale from inside the coolant passages, as leftovers can come loose later and clog holes from head to block causing "hot spots" around cylinders and valves. Good luck
1936.....600001 - 600322
1937.....600323 - 600469
Old 05-10-2008, 11:02:19 AM
Thanks a bunch guys. This is going to be the next project.
Dave
Twin City 40 Tom Cwach Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 11-16-2016 03:03:49 PM
Twin City LT David Parfitt Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 17 12-02-2008 09:28:42 PM
Twin City 17-28 Phil Johnson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 18 12-28-2007 12:03:49 PM
17-28 ty twin city Bear Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 01-14-2006 12:00:12 PM
500 H.P. Twin City Tanner Remillard Steam Stationary Engines, Traction Engines, Steam Boats 2 07-17-2005 12:13:02 PM
