Another Twin City
this thread has 132 replies and has been viewed 12603 times
Old 12-09-2016, 01:01:18 PM
Nebraska Kirk Nebraska Kirk is offline
Default Re: Another Twin City
I see no need to drill 6 more holes when you only need 3. That is not to say that you should not, just that you really don't need to. The disc won't be out of balance with 9 holes in it versus 12.
The Following User Says Thank You to Nebraska Kirk For This Post:
Old 12-09-2016, 02:51:46 PM
Ditto on what Kirk said. You only need 3 new holes drilled in the center clutch disc. The timing gears in your engine are better than the ones in mine. If the bushing and stub shaft for the idler gear are good I'd run it.
That ball bearing on post #58 is a common one. If you replace it with a sealed version of that bearing you can easily eliminate the oil leak problem behind the fan drive pulley.
The Following User Says Thank You to Mark Schneider For This Post:
  #63
Old 12-09-2016, 07:10:12 PM
Russ Hamm's Avatar
Images: 1
Duh, i looked at it again and thats right. It will have three sets of three holes done right, equally spaced.
---------- Post added at 07:10:12 PM ---------- Previous post was at 07:08:29 PM ----------
Just got that bearing in today thanks to your thread, mine had a lotta loose.
Old 12-10-2016, 11:29:38 AM
Russ Hamm's Avatar
Images: 1
I just noticed looking over KevinR's 12-20 thread that the driven disc on his tractor has been re-drilled twice, that may be just the plan.
  #65
Old 12-11-2016, 09:49:28 AM
Russ Hamm's Avatar
Images: 1
I had one of the guys at work do some machining yesterday to fit the new input shaft bearing. He did a great job on the housing, turned the shaft down too far and i have to speedy sleeve it. I think he thought it better to true it up and it was worn a little out of round.
When i took the oil pump apart i noticed the drive gear keys were pretty worn and it turned on the shaft some. After cleanup i see the keyway is worn a lot worse.
Old 12-11-2016, 08:40:06 PM
Hi Russ
If the keyways on the oil pump shaft are good yet you could install new keys and flip the gear so it drives on the other side of the slot. If you are uncomfortable with reusing the gear the oil pump gears out of a MM Z or R are the same per info shared by Molinegb recently.
Too bad about the input shaft mistake. On that setup the shaft itself is the inner race. My shaft had a bad spot in it also which is why I went with the ball bearing. My personal view is that the speedi sleeve material would be softer than either the bearing race or shaft. I would be inclined to reduce the shaft diameter to the point a 1/8" wall steel bushing could be press fit on the shaft and then finish off the OD so a nice press fit for the bearing race is established.
  #67
Old 12-14-2016, 12:22:22 AM
Russ Hamm's Avatar
Images: 1
I think we have a plan on the input shaft now, tonight was the time to remove a pound of hardened preservation tack from the oil pan outsides. Wow, i had to sharpen my putty knife three times, and that oil pan is STILL heavy. I think you could have buried it in the ground for a thousand years, dug it up, and it wouldn't have a speck of rust on it.
  #68
Old 12-14-2016, 09:58:02 AM
Molinegb Molinegb is offline
Remember doing the pan on 12-20. Pan on early ones are tin. I must of used a lb of solder repairing pin holes. It is quite light compared to 17-28.
The Following User Says Thank You to Molinegb For This Post:
  #69
Old 12-18-2016, 10:57:19 PM
Russ Hamm's Avatar
Images: 1
Cleaning and more cleaning.
Got the input shaft/ bearing assy figured out and basically done, cylinders are honed / cleaned up. The rear governor shaft bushing had a little wear because the front bearing was in the process of going out, so i drove the bushing out and turned it around. This looks like it will work good for a long while. Second picture is a nail or belting rivet, i suppose, found in the bottom of the timing gear housing of the block. Sorta looked like it went through one of the gears, maybe. Any guesses?
ID:	270542   Click image for larger version
Old 12-18-2016, 11:05:18 PM
Russ Hamm's Avatar
Images: 1
Actually, it kinda looks like a pin for something.
I forgot to ask, has anyone here replaced the pilot bushing in the flywheel and if so would you happen to know the size? I'm bent on doing that but hadn't decided wether i'm going to cut out the old one or macine it a lil and sleeve it as we have some thinner brass sleeves handy.
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 109 11-19-2017 11:39:07 PM
Twin City Big Twin Cam up for Sale Mark Schneider Live Auctions of Engines, Tractors and Old Iron 27 03-19-2017 10:58:08 PM
Twin City KTA ozfarm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 12-29-2013 11:12:27 PM
Twin City 12-20 Pat Bayer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 20 06-10-2012 11:02:28 PM
MM Twin City JTS DavidRaines Antique Farm Tractors 3 05-10-2008 11:02:19 AM
