Hart Parr 18-36 Gear
this thread has 5 replies and has been viewed 908 times
Old 01-19-2018, 07:00:06 PM
Gede20 Gede20 is offline
Default Hart Parr 18-36 Gear
Hello,
A friend of mine is working on a hart parr 18-36 and it turns out the tractor is missing teeth from the intermediate gear in the gearbox. It is the double gear with 3 rollerbearings inside.
Does anyone happen to have one laying around??
Greetings from the Netherlands,
Pim
Old 01-19-2018, 08:33:19 PM
Default Re: Hart Parr 18-36 gear
Maybe trade for a Magneto or a carburetor or a lubricator or pistons for 18-36 Hart Parr.
The Following User Says Thank You to Oilpulled For This Post:
Old 01-19-2018, 11:26:23 PM
Alastair Geddes. Alastair Geddes. is offline
Look into getting one made might be another option if you cannot find one
The Following User Says Thank You to Alastair Geddes. For This Post:
Old 01-20-2018, 09:54:35 PM
Default Re: Hart Parr 18-36 Gear
Build up the missing teeth with weld or body filler first then? Seems like guys do it on here all the time.
Old 01-20-2018, 10:18:38 PM
Renny Renny is offline
Sent you a message. I likely have one that would work.
Old 01-21-2018, 04:13:39 PM
It seems that we found a gear, thanks for the replies.
He is also looking for an aircleaner a gasoline tank and a mufler.
maybe someone can help with that?
18-36 hart parr Hezekiah Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 06-09-2015 08:10:32 PM
Hart Parr 12-27 Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 32 08-23-2014 08:45:15 PM
Oliver Hart Parr Timing Gear Help Needed Tony Thompson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 05-29-2013 10:56:17 PM
1927 Hart-Parr Tractor Governor Timing gear Troy Vetsch Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 08-09-2011 10:21:02 AM
Hart-Parr No. 3 Gary Bahre Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 12-14-2004 09:50:34 PM
