Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Antique Engine Photos
Antique Engine Photos OLD gas engines, hot air engines, Diesels and steam engines. An electronic photo gallery to showcase the best of your old engine collection.
1946 IHC LB Engine
this thread has 0 replies and has been viewed 1429 times
Old 06-27-2015, 04:10:56 PM
dryan117 dryan117 is offline
Default 1946 IHC LB Engine
Bought a non-running IHC LB 1.5-2.5 HP SN#102090 outside of Boston MA. Here is link to my youtube efforts to get it started. I found the fuel check valve stuck and the magneto mis-timed to the engine. Not sure if the governor is working correctly or not, it has a loose/stripped fitting on the fuel supply to the carb so it may be loosing vacuum and/or sucking air.
Also have no idea why this was painted blue.
https://youtu.be/sviEIBNROEk
ID:	228569   Click image for larger version
ID:	228570   Click image for larger version
ID:	228571   Click image for larger version
1946 Farmall M Ben Busfield Antique Farm Tractors 15 11-23-2014 05:41:52 PM
1946 Gardner 1L2 Neville Bond Vintage Diesel and Oil Engines 1 10-11-2014 06:33:07 PM
1946 IH LB First Run After valve job. vinceostapowich Antique Gas Engine Discussion 1 09-27-2012 06:16:10 AM
1946 Lovell wringer washer with a Briggs WMB engine Dengine Antique Washing Machines 0 08-18-2012 06:19:16 PM
1946 Maple-leaf B. K. Lahey Antique Autos and Trucks 0 08-24-2008 10:12:35 PM
