Oil Field Engines
Reid plunger type water pump
this thread has 7 replies and has been viewed 2885 times
Old 05-28-2008, 11:45:32 PM
Ray Ethridge's Avatar
Default Reid plunger type water pump
While looking at a Reid manual reprint I ran across a drawing and parts list of a plunger type water pump that goes on the end of the main shaft past the clutch. It is pretty self-explanatory except for a couple of items. Does anyone know how the pump rod connects to the pump plunger? How does the pump gland seal on the plunger rod when it is going from side to side as well as up and down?
Old 05-29-2008, 03:54:46 AM
Sky Pilot Sky Pilot is offline
Talking Re: Reid plunger type water pump
These pumps are not terribly common, as water will freeze and expand in winter, and in oil field use, plain old water was the coolant of choice ... these humble plunger pumps were often the casualty of not draining all the system when done running for the day.
I have seen them in operation but will leave intellectual reply to your specific questions to those who are younger, better looking and more knowledgeable than I.
Well ...
Younger and more knowledgeable, anyway!
The Following User Says Thank You to Sky Pilot For This Post:
Old 05-29-2008, 07:57:07 AM
Earnie Hampton Earnie Hampton is offline
John Burns is currently reproducing these pumps, and he can probably tell you the full story on them.
Good Luck
Earnie
The Following User Says Thank You to Earnie Hampton For This Post:
Old 05-29-2008, 10:32:57 AM
Russell Farmer's Avatar
Russell Farmer Russell Farmer is offline
Default Re: Reid plunger type water pump
see video of ours.
http://youtube.com/watch?v=3wGsdUl4xBk
Seals on piston not rod, I used an air brake pod clevis for the wristpin on mine.
The Following User Says Thank You to Russell Farmer For This Post:
Old 05-29-2008, 03:04:07 PM
Sky Pilot--- Thanks for the info, I guess I might think about a drain for it then, it might actually freeze down here sometime. That is a detail that is hard to think of in Texas when it is in the mid 90's!
Earnie--- Thanks, you are right! I have one on order.
Russell --- Fantastic engine! I hope to have mine looking like that some day. And a picture is definitely worth a thousand words, I can see how it all works now.
Old 10-19-2008, 09:47:23 PM
Rusty Greiner Rusty Greiner is offline
I have a story to tell you about these water pumps. While we were in Portland in August one of the Reid engines being displayed had a water pump installed. Brian (the owner) told me the body of the pump came from ohn Burns. Brian placed a steel strap on the clutch side of the flywheel running it from one clutch hole to another on the other side. He welded a post about 1inch in diameter to match up to the plunger rod for the pump. It was a very good design. It appears there was a plate the did the exact thing Brin's strap did. Now for the best part of this story. About 30 minutes after seeing Brian's reproduction pump and setup I discovered a water pump with all attachments in the selling area for less than Brian paid for his repro. (smiling widely). The best thing about my find was discovering that my find was an ORIGINAL Reid pump. The only one I have ever seen. Good luck.Rusty
Old 10-20-2008, 10:19:53 AM
You are one lucky guy Rusty! Especially when you consider I was also at Portland in August scouring the place for Reid parts I needed, with that high on my list. You beat me to it!
Old 10-20-2008, 03:10:02 PM
Tom Winland's Avatar
Tom Winland Tom Winland is offline
Banner Sponsor
Images: 8
I have a couple original pumps hanging on the wall in my engine shed just never know when I'll need one also have original brass gasoline carb.
Tom Winland
Ohio
Lister ST1A lift pump plunger rod? Keith Kessler Vintage Diesel and Oil Engines 5 06-19-2008 01:04:01 PM
Novo fuel pump plunger length? Edwin Antique Gas Engine Discussion 3 05-03-2008 08:31:00 PM
Another FM question-fuel pump plunger Preston Wells Antique Gas Engine Discussion 0 07-22-2007 07:41:27 PM
Reid Water Pump Russell Farmer Oil Field Engines & Related Equipment 2 07-01-2007 06:26:55 PM
Plunger pump Andre' Blanchard Steam Stationary Engines, Traction Engines 4 03-08-2004 02:18:55 AM
