Generator Head Alignment
this thread has 7 replies and has been viewed 511 times
Old 12-09-2018, 12:35:24 AM
westcoaster westcoaster is offline
Default Generator Head Alignment
What's involved with aligning a generator head with it's engine?
This would be a two bearing generator head mated end to end with an engine, guessing using something similar to a rag joint in automotive steering.
Seller of the genset advises alignment of the generator to the engine.
Generator and engine mounted on parallel I beam tied together. mounting plates for both engine and generator head have already been drilled but can imagine a small amount of play in the mounting bolts can play havoc with the bearings.
How does one go about aligning a generator head with it's engine? Special tools?
Old 12-09-2018, 05:33:37 AM
drumfield drumfield is offline
Default Re: Generator head alignment
If you really want it to be right, you would need access to a full blown machine shop for the instruments of accuracy, and an "impulse" rated Lovejoy coupling. Otherwise, change the setup to "side-by-side", and use pulleys and belt.
Old 12-09-2018, 08:53:19 AM
RobW RobW is offline
Enter 'Shaft coupling alignment methods' into a search; you will get quite a bit of information.
Old 12-09-2018, 02:04:14 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Generator Head Alignment
The smart way to do this is to use a LoveJoy type Coupling... This doesn't require near as much precision in the alignment as a Hard Coupler....
Bruce in alaska
Old 12-09-2018, 04:21:00 PM
John Newman, Jr.'s Avatar
Default Re: Generator Head Alignment
www.surpluscenter.com
Is a good source for LoveJoy shaft couplings. Good prices, too.
https://www.surpluscenter.com/Catalo...log291-140.pdf
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
The Following User Says Thank You to John Newman, Jr. For This Post:
Old 12-09-2018, 05:09:48 PM
Seems heads are usually just aligned by the bolts and / or studs, even on a V8 where the intake manifold must line up as well. Don't think I've seen any with dowel pins...
For a shaft coupling between an engine and a generator, it seems the LoveJoy ones make a racket and die an early death due to the constantly reversing torque applied to them. At least when a single cylinder engine is used...
In this regard, a rigid coupling would be best, but then shaft alignment needs to be perfect, and stay that way, even as the engine and generator twist the frame under load.
I'd definitely select a coupling that is specifically designed to handle the impulse loads, as was stated above.
If your generator is two pole, the belt and pulley set up is the way to go, to get the engine speed down to something less grating on the nerves. I have a Wisconsin driven Winco that runs 2400 rpm, performs quite respectably, and isn't unpleasant to listen to. Like this: https://www.youtube.com/watch?v=6hvpFM8-qiU
The Following 2 Users Say Thank You to Vanman For This Post:
Old 12-09-2018, 09:49:50 PM
It would be a Lister HA2 coupled to a Kato 10kw head.
I'm thinking that would make belt drives a little more difficult unless a guy were to find a cog belt...
Although side by side would make the footprint a little smaller...
Lovejoy coupler... Never heard of one before, Time to google...
The Following User Says Thank You to westcoaster For This Post:
Old 12-09-2018, 10:17:26 PM
DustyBar DustyBar is offline
I worked on something similar 35 years ago. It was direct coupled and the alignment was maintained by tapered pins in taper reamed holes in the mounting pads of both generator and engine. I had to remove it to do some work on the engine but it went back into place exactly right.
Key Way Groove Alignment pfc123 Wisconsin Engines 4 10-05-2018 06:47:43 PM
Crank alignment Jeremy Hartle Antique Gas Engine Discussion 14 01-04-2015 02:15:42 AM
Connecting Rod Alignment Graeme.R Antique Gas Engine Discussion 2 06-20-2014 06:11:43 PM
belt alignment MarkBillesbach Antique Gas Engine Discussion 7 06-03-2012 10:51:32 AM
WHEEL ALIGNMENT!! Russell Gilbert Antique Engine Archives 2 09-23-2000 03:59:28 AM
