Need help to ID generator
this thread has 5 replies and has been viewed 470 times
Old 12-09-2018, 06:50:45 PM
BHoward BHoward is offline
Default Need help to ID generator
This generator was on a 6 hp Petter AVA1T NO.3129011 diesel. It has 4 slip rings and a wide commontater with 2 rows of 4 brushes placed all the way around and stagerd.
Old 12-09-2018, 09:19:13 PM
Default Re: Need help to ID generator
Looks like four pole, so 1800 rpm for 60 cycles.
Commutator means self excited, and possibly exciter cranked as well.
Four collector rings could mean single phase reconnectable between 120 or 120/240, OR, 120/208, three phase, OR 120/240, three phase. . Or for that matter 277/480, or almost anything else.
Old 12-09-2018, 09:39:23 PM
moteurdelco moteurdelco is offline
probably a Stamford 3kw,115|230 volts of early '60;late fifties.
or a Brush .
Old 12-09-2018, 10:14:43 PM
Thanks for the replyes. It dose have the name Stamford on the plate of the whole unit, and dose crank when I put 24 volts to the solnoid in the controle box but gen would,nt put out any power. I would like to find a wiring diagram.
Old 12-10-2018, 12:30:16 AM
AlanR AlanR is offline
These threads may be of some assistance:
https://www.smokstak.com/forum/showthread.php?t=41570
https://www.smokstak.com/forum/showthread.php?t=133048
Alan
The Following User Says Thank You to AlanR For This Post:
Old 12-10-2018, 05:36:01 PM
Thank Allan for the links. One of those gens looks like it,s from the same manufacturer but a different model. Here of what I assume is a voltage regulator and one of the wires was broken off the pull down coil. There was a broken spring on one of the slip ring brushes. A friend gave me this set more than 20 years ago and I got it running , used it to build a house then it quit making power. Then I left with another friend to have a look at. He covered it with a tarp and there it sat for 20 years. I even for got I had it. So now after being on Smokstak for a few years , thout I,d take a look at it
Mystery Machine! AC Generator? Double Current Generator? Vanman Generators & Electric Motors General Discussion 2 10-14-2018 06:21:11 PM
Kohler 23eoz 230v generator decides it's a 400v generator haveaday Kohler Generators 21 08-06-2016 12:43:55 PM
Onan Fairbanks Morse v45s-20 generator light plant my first vintage generator DaveinRI Onan Generators 32 06-19-2014 03:19:24 AM
Generator Project 1920 Dodge 4 Cyl. Side Valve and Western Electric Generator jeffery flynn Antique Gas Engine Discussion 7 05-27-2010 02:43:27 PM
Sears companion 5000 watt generator needs generator unit daytonakid Generac Generators (SEARS, etc.) 1 05-17-2010 04:21:46 PM
