Wisconsin 8kw 2cyl Generator
this thread has 4 replies and has been viewed 343 times
Old 01-06-2019, 06:48:15 PM
DJB6.03CE DJB6.03CE is offline
Default Wisconsin 8kw 2cyl Generator
What is it and should I get involved with this, only a hour away and listed for 600 I’d much rather pay like 200.
Owner is going to try and find the tag, no word if it runs and produces power yet.
Old 01-06-2019, 10:04:02 PM
Default Re: Wisconsin 8kw 2cyl Generator
At only 8 kW with a 2 cylinder engine, I suspect it is a 1800 RPM generator, and not a 3600 RPM "screamer." That's a definite plus! Wisconsin engines are good, heavy duty industrial engines. They will last forever with proper care. If it hasn't been run in a while, there is a seal on the oil pump that should be checked. Someone else on this board may chime in to tell you what to look for. Unfortuntely, I don't know.
For its age, the generator set appears to be in good condition. The orange color was Pincor's (Pioneer Gen-E-Motor) signature color. From the photo, it's hard to tell whether it's orange, red, or reddish orange. It may be a Pincor, or something else. Personally, I wouldn't be interested in it at $600, but it may be worth that to someone. $300-$400 would be my top offer, and that's only if it runs. I understand that generators in Canada tend to be priced higher.
The Following User Says Thank You to Steve Dawkins For This Post:
Old 01-07-2019, 03:13:30 AM
Dan A S Dan A S is offline
Hello, It looks like its made by Win-power, if its 4 pole and 1800 RPM its more like 6000 watt, I had one about 20 years ago and it was a 6KW 120/240 V 1 PH . ok if you dont need portability because of weight. It was probably made in the 80s it pulls the AC power from the armature so you want to make sure the brushes are good and free in the holders if its been setting around.
The Following User Says Thank You to Dan A S For This Post:
Old 01-07-2019, 10:38:35 AM
Jack Hottel Jack Hottel is offline
Looks like a WINPOWER GE6W4-C (single phase) or -D (three phase). 6KW, 120/240VAC, 1800 RPM. Wisconsin TJD engine, 11.7 HP at 1800RPM. About 575LBS. Data Sheet dated 9/15/1969.
Good luck,
Jack Hottel
The Following User Says Thank You to Jack Hottel For This Post:
Old Today, 09:14:35 PM
ArodaPowerCo ArodaPowerCo is offline
If that's an 1800 rpm unit it'd be worth a look. Those are great engines. There is a check ball in the oil pump that likes to stick. There is a metal line that runs to the governor; loosen it and turn the engine over to see if oil comes out. If it does, the ball is not stuck. Valves like to stick open too when they sit for a long time. Extremely reliable engine. I have one on a wood splitter and another on a 10kw Winco 2 pole screamer.
You will need a generous fuel budget. They are THIRSTY.
onan generator 2cyl aircooled elhector2007 Military MEP and Aircraft Gen-Sets 2 06-14-2015 11:38:23 AM
Need Help Identifiying 5kw Onan 2cyl Diesel Military Generator rickhshoey Onan Generators 4 06-12-2015 03:51:38 PM
Anyone know anything about 2cyl Wisconsin engines? Dwayne Venema Wisconsin Engines 15 02-18-2009 09:47:28 AM
Can I add electric start to Wisconsin 2cyl. Welder? rebsar Wisconsin Engines 6 11-29-2008 09:15:19 PM
Novo 2cyl. Roger Kirschenman Antique Gas Engine Discussion 9 07-07-2006 12:35:54 PM
