Onan 4.0 CCK Spec V
this thread has 22 replies and has been viewed 788 times
Old 09-19-2017, 06:55:56 AM
reid070 reid070 is offline
Default Re: Onan 4.0 CCK Spec V
Originally Posted by slip knot View Post
that's a pretty clean set. I'm jealous.
Yes it's in great shape, I couldn't say no to this one. Pretty unusual for around here, great shape and a reasonable price. Surprisingly it sat on Kijiji for 3 weeks while I was away at work with only 1 other caller who never called back! Lucky for me.
Seller is retired electrician who removed it for a customer ( they replaced it with a new kohler). He said it spent its life in a heated building connected to a transfer switch, so not likely many hours.
Steve
Old 09-19-2017, 08:26:28 PM
Ran set for awhile today , charging voltage settled down to 13.8volts so looks like that's working ok. Oil leak looks to be coming from piviot pin on fuel pump. Pin was sticking out 1 side ,pushed it back in flush still leaking though. I was able to get a wrench on 1 of the mounting bolts ,it was snug.
Any of the manuals and wiring diagrams I've been able to grab only go to spec u. I can't find anything that mentions spec v?or is there no real difference ?
Thanks Steve
Old 09-19-2017, 11:19:15 PM
Motorhead's Avatar
Motorhead Motorhead is online now
With the fuel pump pin in proper place, get a small center punch and stake around the aluminum to hold the pin in place. Clean around the pin and casting with some lacquer thinner and let dry. Put some silicone sealer around the pin and let it set up for a day or two. should stop or at least slow it down.
The Control panel
and gauges of my
7.5JB
Old 09-20-2017, 11:34:34 AM
MBB MBB is offline
Regarding manuals the index lists those manuals for spec v also. I would say then little difference.
The Following User Says Thank You to MBB For This Post:
Old 09-23-2017, 07:24:49 PM
Had some time with this one today. Decided to do a compression test ,before I warmed up the set and changed the oil. Surprise ! 140 psi . I had recently read Johnnyc's thread on his former cck set and the debate about high comp heads. Looked at all the pic's I could find of the raised bump on the head that indicates high compression . Looking at my set ,nope no raised bump.
So... I had to know for sure , off with the heads. And they are absolutely high compression . And I found the raised area,but not in the spot shown in other threads. The raised area on my heads is on the top horizontal cooling fin almost out of sight under cooling tin. The pictures of other heads show the hump on the last vertical cooling fin near the plug.
Interesting stuff to me anyway, as I didn't think(from what I have read here) a tri fuel cck would have used the high compression heads.
The part #'s on the heads were170 0732 and 170 0733. An other thread by Kevin K shows these part #'s as ccka heads? Pretty sure this cck has never been apart before. I wonder does it show the type of head on a build sheet?
Steve
---------- Post added at 08:24:49 PM ---------- Previous post was at 08:11:14 PM ----------
Whoops sorry I screwed up those part #s should be 170 3071 and 170 3072.
Old 09-23-2017, 07:32:44 PM
Kevin K Kevin K is offline
This should be your production order. Sometimes they used the older -3CR designation instead of the newer FJ.
Are you running on gasoline or propane? I tried a set of high compression heads on my gasoline fueled 5CCK and got readings of 145 to 150PSI. I thought that may be a bit high for our crappy ethanol gasoline, so I put the standard heads back on. I usually use non ethanol high test, but in a long duration power outage I am concerned it may not be available.
The Following 2 Users Say Thank You to Kevin K For This Post:
Old 09-23-2017, 07:34:10 PM
In this picture from onan parts you can see the raised area where I was expecting to find it.
On mine it was instead (looking at the combustion chamber) on the top to the left of the spark plug hole. Also it was not nearly as pronounced .
Old 09-23-2017, 07:36:25 PM
I have one set of high compression heads without the raised area. Go figure...
Old 09-23-2017, 07:40:51 PM
Thanks Kevin. I haven't tried it on gasoline yet , but I would like to be able to run it on gasoline. One of the thing I did today was set the timing back to 21 degrees , it was at something that didn't even line up with my timing marks (they stop at 22°) judging by the distance above the last mark it was probably >26°.
Steve
Old 09-23-2017, 08:01:14 PM
Advancing the timing is a good idea when running on propane, a slower burning fuel. You have to make sure to set it back to standard before running on gasoline. Mark the original timing adjustment so you can reset it if needed. I think standard was 0.020" on the points, which gives you 19 degrees BTDC. The spark plug gap is listed as 0.018" on propane, and 0.025 inches on gasoline.
Onan BGE spec N Kpack Onan Generators 2 09-20-2014 10:49:46 AM
Onan 6.5 NHE Spec. A alphasud Onan Generators 3 08-25-2013 11:51:18 PM
Onan AJ Spec S help Leeann Onan Generators 8 07-15-2012 05:25:09 PM
Onan 4. BGE spec E help please darrenholz Onan Generators 3 09-23-2011 09:11:09 PM
Re: ONAN CCK Spec R Help jecho Onan Generators 1 04-14-2011 08:15:16 PM
