How do I use an Onan build sheet.
this thread has 3 replies and has been viewed 197 times
Old 09-22-2017, 10:16:11 AM
wxyoung2008 wxyoung2008 is offline
Email NOT Working
Default How do I use an Onan build sheet.
I know what a build sheet is. I have occasionally requested manuals and the build sheets were provided to me as well. But occasionally I have seen members request a build sheets only for their units.
How do you incorporate a build sheet in with the Maintenance, parts , and other manuals .
Is it used in case your unit has been Frankensteined and you want to know its true options when it left the factory ?
I know that it has been said that there are no stupid questions and ..... I am probably pushing the envelope here, but I had to ask.
Old 09-22-2017, 10:28:57 AM
Kevin K Kevin K is offline
Default Re: How do I use an Onan build sheet.
I use it mainly to get the wiring diagram number so I can post the diagram to help people out.
The option list occasionally comes in handy when checking for things like a dual fuel carburetor or extended stack from a Craigslist post prior to seeing it in person.
Not pushing the envelope, it's a good question. Maybe someone else has an additional use.
The Following 3 Users Say Thank You to Kevin K For This Post:
Old 09-22-2017, 11:17:31 AM
The rotor and stator numbers on them can sometimes be helpful.
The Following 2 Users Say Thank You to nothingbutdarts For This Post:
Old 09-22-2017, 11:42:36 AM
Billy J Shafer's Avatar
The build sheet will only tell you what it left the factory with. Plus any changes are updates at the time. Will not list anything put on at a later date. It is good to have when looking up print numbers and other information.
There is no stupid question. If you knew you wouldn't be asking.
The Following 4 Users Say Thank You to Billy J Shafer For This Post:
Onan 15 JC build sheet? nothingbutdarts Onan Generators 7 06-07-2017 11:48:15 AM
Onan 12.5 Build Sheet Please J-Man Onan Generators 11 02-05-2016 10:59:40 AM
Onan 12.5JC build sheet mhasemann Onan Generators 17 03-25-2015 07:18:41 AM
Onan 6.5 NH build sheet squidtrap Onan Generators 5 10-07-2014 04:59:22 AM
Onan 15.0JC Build sheet JSConan Onan Generators 6 01-05-2012 07:49:52 PM
