Air Compressors
American Air Compressor Type 735-60
this thread has 3 replies and has been viewed 726 times
Old 06-26-2018, 06:35:05 PM
Nubian Nubian is offline
Default American Air Compressor Type 735-60
Hello all!
Just got my hands on the above title. Know nothing about it, looks to be a 2 stage. 5hp magnetek motor, 1745 rpm, needs parts like air filter etc. tank is date stamped 1974, not sure what type oil pump takes, and a manual source.
any help appreciated thanks
Old 06-26-2018, 07:09:09 PM
Default Re: American Air Compressor type 735-60
Air filters are pretty generic, find what works unless you need original. Oil would most likely be 30wt NON Detergent. If you want to play safe, hydrostat test the tank.
Old 06-27-2018, 02:39:57 AM
Thanks, also id tag on tank says it’s 3 ph yet motor on it (magnetek 1745 rpm) is a single phase. Specs for that pump (similar to Saylor-Beall)looks to be 845rpm? any idea where to find owner/parts manual?
Old 06-27-2018, 03:55:04 AM
Default Re: American Air Compressor Type 735-60
Found it
http://www.saylor-beall.com/wp-conte...riesManual.pdf
Kellogg American 321 Compressor Pump cfm? skindaddy Air Compressors 6 03-29-2018 12:25:17 AM
1928 American Lafrance Type 145 PWT. mckenziejoshua Antique Autos and Trucks 6 12-23-2017 11:32:45 PM
American Jenbach Diesel Compressor DavidRaines Hit & Miss Gas Engine Discussion 7 07-04-2016 04:10:56 PM
American Kellogg 321 compressor EnginePat Machine Shop and Tool Talk 18 05-04-2015 02:50:16 AM
American Bosch Magneto DUI ED.18 what type of engine or machine was this used for? Victor W Magnetos, Ignition Coils and Spark Plugs 0 11-06-2008 01:40:02 PM
