John Deere D Burns Oil
this thread has 4 replies and has been viewed 1301 times
Old 08-28-2015, 04:54:54 PM
bben486 bben486 is offline
Default John Deere D Burns Oil
We have a 1928 John deere D and once it starts the exhaust is clean no problem but as it runs for awhile it starts to burn oil, opened the compression release on the left side while it was running and saw oil the right side was clean as could be. So is this a ring problem or something else ? I just find it hard to believe it's the rings cuz the tractor was restored 15 years ago but never run and after I get it running it burns oil . Thanks so much
Old 08-28-2015, 04:58:12 PM
LukeSte LukeSte is offline
Default Re: John deere D burns oil
couple things to check.... is the oil level correct and not over full. could the rings be stuck? get it out and work it. takes time to get oil to head....maybe guides. work it for a while first, and see what you have.
Old 08-28-2015, 07:42:10 PM
lukeste is right.
If it was never run much after the rebuild take it out and beat the snot out of it.
Rings will never seat just puttering around.
Old 08-28-2015, 11:03:21 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Default Re: John Deere D Burns Oil
That and the fact that unless it has been rebored, the bores are slightly out of round and will require a bit of time to run in. We got one here that has the same issue, never burned oil till we put in new rings. Now it smokes a bit but doesn't foul plugs, next time I'll over bore it and put in new pistons as well.
Old 09-09-2015, 08:51:39 AM
R Pope R Pope is offline
I agree, work it hard and get the temp up good. Keep it working a day or so and the rings should seat better.
A 4hp REID project by John Burns John Burns Oil Field Engines & Related Equipment 407 11-19-2018 10:03:54 PM
John Deere & John Deere Bain horse drawn mowers Amosalmo Horse Drawn Equipment 4 05-18-2012 11:35:01 AM
John Deere A and John Deere R For Sale (Stuck in the snow!) Gary Biewer Antique Farm Tractors 11 01-25-2011 06:33:52 PM
John Burns New email address John Burns Oil Field Engines & Related Equipment 0 09-29-2010 01:44:50 PM
Waterloo Billy Boy Tumbles John Smyth 8hp gas tank on John Deere H RobGill2008 Hit & Miss Gas Engine Discussion 4 02-09-2010 01:15:43 AM
