Oil Field Engines
A 4hp REID project by John Burns
this thread has 407 replies and has been viewed 123924 times
Old 01-23-2010, 11:43:28 PM
John Burns John Burns is offline
Default Re: A 4hp REID project by John Burns
Been working on the side rod bearing, here are a couple of shots!
John
ID:	72138   Click image for larger version
The Following 10 Users Say Thank You to John Burns For This Post:
Old 01-24-2010, 11:06:03 AM
Tbar Tbar is offline
I am getting into this thread about 2 years after the fact........VERY impressive.
After having been around castings and machining for several decades I gotta ask.........
Where did you find the casting pattern drawings?
Where did you find the machining drawings?
I am afraid to ask what the pattern making cost.
Did you find any voids or sand pockets in the parts? They seem to show up when your 90% into the machining process.
Tbar
Old 01-25-2010, 12:23:28 AM
Dear tbar, I reverse engineer the origonal engine, I cut up three cylinder castings to make sure we got it right. Had to make some wall thickness corrections ect.
John
Old 01-28-2010, 02:18:03 AM
Charging piston rods almost complete, have to drill and tap for milk can oiler and oil gallery. I also have to split the bearing brasses.
John
ID:	72479   Click image for larger version
ID:	72480   Click image for larger version
ID:	72481   Click image for larger version
The Following 9 Users Say Thank You to John Burns For This Post:
  #105
Old 01-28-2010, 02:19:26 AM
Ray Cardoza's Avatar
Looking good. cant wait to see a finished engine up and running
Old 01-28-2010, 02:22:38 AM
Additional pics of side rod
John
ID:	72485   Click image for larger version
ID:	72563   Click image for larger version
The Following 6 Users Say Thank You to John Burns For This Post:
  #107
Old 01-28-2010, 02:30:59 AM
Looks good
Old 01-30-2010, 12:08:57 AM
Last pic of side rods,
five in the box, ready to go....we be fast and they be slow....
John
ID:	72612   Click image for larger version
ID:	72613   Click image for larger version
The Following 8 Users Say Thank You to John Burns For This Post:
  #109
Old 02-02-2010, 02:08:50 AM
Started to machine the main connecting rods today, here are a few pics!
John
ID:	72835   Click image for larger version
ID:	72836   Click image for larger version
  #110
Old 02-04-2010, 11:53:14 PM
FArmstrong FArmstrong is offline
Rods are looking good!
Old 02-10-2010, 03:08:24 AM
Rods turned and rough polished, five,
jjb
  #112
Old 02-21-2010, 06:12:05 PM
John Davis's Avatar
John Davis John Davis is offline
John,
I have been reading, looking at this thread and have enjoyed it very much. Great job! Being a manual and CNC machinist myself also engine collector and restore of gasoline engines a few questions come to mind.
(Keep in mind I'm not to knowledgeable about oil engines.)
On the average how much is an original complete running 4 hp Reid engine valued at?
Paying someone else to do the castings and machining is going to cost you a small fortune!
You hope to get a return on your money from selling the castings?
Just trying to figure out why a person would put as much time and money in a project unless he figured he would get most of his money back? Must be a fairly rare engine?
I guess it's not always about the money and time....Keep up the great work!
Old 02-22-2010, 03:37:49 AM
Dear John!
The last 4hp REID I personaly saw sold for in excess of $27000..
Yes this is and expensive project, more of a labor of love. I used to make ( design/build/sell) the 1/4 scale model REIDS
so this is my part of the hobby. If we sell any castings it will help defray the cost, not gain any money.
I do not collect engines anymore, retired I have the models I built, so this will be another model (100%) scale.
Thanks for the questions, though, it helps me keep my sanity!!!
John
The Following 2 Users Say Thank You to John Burns For This Post:
  #114
Old 03-03-2010, 07:51:41 PM
While waiting for replacement castings for lower rod bearings I machined the governor drive pullies!
John
The Following 7 Users Say Thank You to John Burns For This Post:
  #115
Old 03-06-2010, 08:59:27 PM
Screws and pulleys made,and blackened! On to the lower rod bearings!
John
  #116
Old 03-11-2010, 01:46:12 AM
Went to machine shop today to discuss machining bores on the engines. Here are some pic's
John
ID:	75180   Click image for larger version
ID:	75181   Click image for larger version
ID:	75182   Click image for larger version
  #117
Old 03-11-2010, 02:44:24 AM
So how are the bores going to be done ? is the steel plate looking tool ? goin to be used ?
Old 03-11-2010, 06:44:41 PM
The plate has a hole bored in the center,it also has a hole bored at 12" , this is the center to center finished dimention.
The casting has matching holes machined! When you orient the plate to the vertical lathe, you then pin the casting for location to the plate. Bore the cyl, remove casting, switch casting around and repeat. This insures the 12" dimention and expidites the change over from casting to casting. Remember we are machining five cylinder,
John
  #119
Old 03-12-2010, 06:56:33 PM
Lower rod bearings process!
John
ID:	75290   Click image for larger version
ID:	75291   Click image for larger version
  #120
Old 03-15-2010, 09:29:00 PM
More pics of rod machining process!
John
ID:	75520   Click image for larger version
ID:	75521   Click image for larger version
John Deere D Burns Oil bben486 Antique Farm Tractors 4 09-09-2015 08:51:39 AM
Burns Built Reid 4HP. Russell Farmer Oil Field Engines & Related Equipment 1 06-01-2014 01:57:21 AM
Reid 20 HP project neilert Oil Field Engines & Related Equipment 28 02-25-2013 12:32:46 AM
John Burns New email address John Burns Oil Field Engines & Related Equipment 0 09-29-2010 01:44:50 PM
25 Hp Reid - New project! Chuck Martin Antique Engine Archives 10 07-07-2004 01:29:39 PM
