Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Generac Generators (SEARS, etc.)
Generac Generators (SEARS, etc.) Restoring, maintaining and operating Generac generators.
Dayton/Generac 8KW diesel finished and installed
this thread has 6 replies and has been viewed 3821 times
Old 01-14-2011, 01:34:41 AM
Motorhead's Avatar
Default Dayton/Generac 8KW diesel finished and installed
I showed some pictures of my Dayton genset a couple of weeks ago. Since then I got the day tank Rhino lined and reinstalled. I finally got my trusty Kubota tractor and gently pushed it into place in my carport. I had a muffler shop make up a tail pipe for me that now goes through the one panel I added to the carport to keep the rain off of the generator. The panel is easily removed to get to the left side of the generator.
I ran the set wit a 40amp combined load for 25 minutes and the temp gauge ran at 160deg. which is what the thermostat is rated.
I installed both the temp gauge and fuel level gauge. Both will be handy to monitor the generator.
I filled the tank full and added a half a pint of two stroke oil for added lubricity of the ultra low sulpher fuel.
Now I just wait for the power to go out.
Name:	Dayton 015 (Large).jpg
ID:	97850   Click image for larger version
Name:	Dayton 019 (Large).jpg
ID:	97851   Click image for larger version
Name:	Dayton 020 (Large).jpg
ID:	97852   Click image for larger version
Name:	Dayton 018 (Large).jpg
Old 01-14-2011, 09:42:59 AM
Default Re: Dayton/Generac 8KW diesel finished and installed
Very nice work!
Old 01-14-2011, 09:48:37 AM
K D Redd K D Redd is offline
Now Murphy's Law kicks in. With a permanently install stand-by generator, your power will not go out. All of the hour the engine will acquire will be from exercising the unit.
Kent
The Following User Says Thank You to K D Redd For This Post:
Old 01-14-2011, 01:39:06 PM
Motorhead's Avatar
Kent
My thoughts exactly!
Old 01-15-2011, 11:10:19 AM
armandh armandh is offline
be sure to put all the panels back on to keep the critters out.
Old 01-15-2011, 05:20:37 PM
Motorhead's Avatar
I did and I also LOCKED them to keep the "Two Legged" critters out!
Old 01-16-2011, 12:51:48 PM
Jerry Akins Jerry Akins is offline
Kent
So true! Spent 2 years rebuilding a Kubota genset after Katrina destroyed our home. It has been over 5 years, since Katrina, without a power glitch, and more importantly NO HURRICANES! Appears to be a good investment!
My Dayton/Generac 8KW Diesel genset Motorhead Generac Generators (SEARS, etc.) 9 12-27-2010 03:39:25 PM
Generac Diesel 15KW 89A02206-S RJay Generac Generators (SEARS, etc.) 24 12-17-2010 01:17:34 PM
Dayton Generac 8kw standby with no power phabib Generac Generators (SEARS, etc.) 19 03-16-2010 03:32:01 AM
Dayton (WW Grainger) 5kW Diesel B.Ikard Generac Generators (SEARS, etc.) 3 09-08-2008 12:13:07 AM
Generac diesel generator Ed Herrick Generac Generators (SEARS, etc.) 6 02-11-2006 02:27:47 PM
