Fairbanks Morse 3hp - need help
this thread has 1 replies and has been viewed 9984 times
Old 12-23-2004, 01:55:22 PM
Ken Adamson Ken Adamson is offline
Default Fairbanks Morse 3hp - need help
I have a 3hp “Z”, throttle governed engine. I pulled it out of a brier patch about a year ago and have not had much luck finding out anything about it, nor getting it to start. I have only been able to work on it part time and want more time to tinker, therefore I think that the timing needs adjusting. At what position should the piston be in when the ignition fires?
Thank you
Ken Adamson
Old 12-24-2004, 01:04:12 AM
Default Re: Fairbanks Morse 3hp - need help
There should be a timing mark on the cam gear that will align with the flywheel key. The mag should latch off about 20 to 25 degrees before top center, if there is no retarder on the cam gear.
Help with FAIRBANKS MORSE Mod. 32 JHFoster Vintage Diesel and Oil Engines 2 01-22-2006 06:36:13 PM
Fairbanks & Morse Gen. Set Heller D. Davis Generators & Electric Motors General Discussion 1 09-11-2002 09:59:59 PM
Fairbanks-Morse John H Antique Engine Archives 2 11-04-2001 04:18:23 PM
HELP ON FAIRBANKS MORSE TOM BABYLON Antique Engine Archives 6 10-17-2001 06:47:56 PM
Fairbanks Morse ZC Tony Pitts Antique Engine Archives 3 09-30-2001 10:05:34 PM
