Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Horse Drawn Equipment
Horse Drawn Equipment Old iron designed for the purpose of hitching up to a horse or a team. This old iron machinery may be used or demonstrated while hooked to an old iron tractor too.
Wooden wheel bearings
this thread has 11 replies and has been viewed 2082 times
Old 03-14-2017, 08:34:24 PM
Osage Orange Osage Orange is offline
Default Wooden wheel bearings
I am rebuilding a John Deere 999L corn planter. Does anyone know of a source of the wooden wheel bearings for the main wheels? Thanks.
Old 03-14-2017, 08:57:53 PM
Default Re: Wooden wheel bearings
Never had to look for them myself, But as a young child, I recall our neighbor making his own out of some hardwood, possibly maple as it was light colored if I remember correctly.
I just googled wooden wagon wheel bearings, and a couple places said to use black locost wood, as it pretty durable.
http://boards.straightdope.com/sdmb/...d.php?t=648811
Scroll down a couple posts and they discuss it a bit, and there is a link to the wood.
Hope others chime in as now I'm curious to.
Old 03-14-2017, 09:03:59 PM
Kent McMakin Kent McMakin is offline
It was common to use hard maple soaked in oil.
Old 03-14-2017, 09:43:52 PM
Clifford Bridgford Clifford Bridgford is offline
I have found the best wood for bearings is lignum vitae. I have used this on disc harrows that I have restored. You can buy blocks of it from Rockler Woodworking. It was originally used for propeller shaft bearings on ships.
Cliff
Old 03-14-2017, 10:36:41 PM
Joseph Cissell Joseph Cissell is offline
Sir, Find you a Amish Wheel Write. He can make them for you. Joe A.
Old 03-14-2017, 10:55:56 PM
gootsch gootsch is offline
Last I knew the Wooden Bearing Company in Arrowsic, Maine was still in business. They made their bearings using a very good grade of rock maple saturated with paraffin.
The Following 3 Users Say Thank You to gootsch For This Post:
Old 03-17-2017, 11:55:13 AM
Mike Rock Mike Rock is offline
http://woodexbearing.com/
Still there.. wonderful website.
The Following User Says Thank You to Mike Rock For This Post:
Old 03-17-2017, 12:53:53 PM
DustyBar DustyBar is offline
I'm surprised lignum vitae makes good bearing material for misc machinery. Generally it is supposed to be water "lubricated". In a propeller shaft bearing it needs to leak a bit to make sure it get the water it needs. If it doesn't drip a bit it will burn out... and probably start leaking.
http://www.lignum-vitae-bearings.com...bine-bearings/ describes it being used for wind turbine bearings but water needs to be supplied.
The Following User Says Thank You to DustyBar For This Post:
Old 03-18-2017, 12:35:51 PM
Frank DeWitt Frank DeWitt is offline
Around here I suspect the Amish are using tapered roller bearings. I have a picture here somewhere of a Amish buggy with a aluminum sq tube frame and aluminum diamond plate floor. All beautifully welded.
Old 05-10-2017, 10:48:02 PM
DTurner DTurner is offline
I don't know why, but I like the black locust , got a lot of that on the farm , made plenty mis strike to drive staples on successfully so it has to be the utimate bearing wood
Wooden Wheel Making Thaumaturge YouTube Old Iron Videos 9 01-13-2017 04:03:18 PM
22-36 Wheel bearings? Matt S Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 01-02-2014 09:55:26 AM
Wheel Bearings flywheelphil Antique Gas Engine Discussion 2 09-20-2012 12:12:49 PM
Wooden Bearings Oberon67 Machine Shop and Tool Talk 21 02-24-2011 05:25:21 PM
Antique wooden power wheel Laisseraller Farm + Industrial Antiques and Collectibles 2 01-10-2009 10:32:52 PM
