Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
W. & B. Douglas, Middletown Conn. Big Sharpening Wheel, lots of Cast Iron
this thread has 6 replies and has been viewed 710 times
Old 08-11-2018, 09:49:58 PM
mschreiber mschreiber is online now
Default W. & B. Douglas, Middletown Conn. Big Sharpening Wheel, lots of Cast Iron
Need help getting it going, What rpm should it run? Stone is 26" diameter and 4" wide. Is it run in water or should there be a drip cup?
video, https://youtu.be/tR2Etqno44U
ID:	316176   Click image for larger version
ID:	316177   Click image for larger version
ID:	316178   Click image for larger version
The Following User Says Thank You to mschreiber For This Post:
Old 08-13-2018, 08:19:36 AM
Emil K Emil K is offline
Default Re: W. & B. Douglas, Middletown Conn. Big Sharpening Wheel, lots of Cast Iron
Nice grind stone! I was just wondering is it possible to get new grind stones from anyone? I have one that needs a new stone.....
Old 08-13-2018, 01:51:39 PM
I guess Thomas Edison had 1 from same manufacturer as mine.:thumbup:
His is in Ford museum greenfield village.
Old 08-13-2018, 11:36:31 PM
StevenC StevenC is offline
The Dalton Minnesota Threshing Show has a sharping stone that is like yours that they demonstrate. They run it in water and if you bring your knifes there they will sharpen them. My uncle always brings his jack knifes with when we go and has them sharpened , he says that they hold there edge longer on a wet grindstone.
The Following User Says Thank You to StevenC For This Post:
Old 08-14-2018, 07:27:40 AM
How do they run it, by hand or motor? How fast does it run? its kinda tuff to find particulars about running the stone in water or using a drip cup to have a slurry paste while sharpening. thanks 4 any help.
Old 08-14-2018, 11:14:15 PM
All I can tell you is that it is run with a gas engine belted to a speed reduction unit then belted to the grind stone. As far as how fast it turns all I can say is that it runs fairly slow, about the same as you would run a pedal grinder. Since it is run in water it can not be run very fast or it would throw water all over the place. Hope this helps.
Old 09-04-2018, 06:58:59 PM
Engine running! Turns out its a 4 to 1 reduction, running @1250 rpm. Counting the chalk mark revolutions the wheel turns about 40 rpm.
2days running video. https://youtu.be/8v3SrK2vMuw
Douglas Pumps Middleton,Conn Kevin Stone Farm + Industrial Antiques and Collectibles 2 01-08-2014 11:04:38 AM
Cast iron wheel identification bergrider01 Farm + Industrial Antiques and Collectibles 7 02-21-2010 01:47:15 PM
Cattail Cast Iron Wheel Tip Paul Gray Antique Engine Archives 9 02-22-2004 12:26:54 PM
Cast Iron Wheel Repairs Dan Burkart Antique Engine Archives 2 08-09-2000 10:42:05 PM
