Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
Flat Belting
this thread has 5 replies and has been viewed 709 times
Old 09-05-2018, 09:52:02 AM
jimbo8259 jimbo8259 is offline
Default Flat Belting
Just curious as to how to take proper care of belting. When not in use should it be coiled up or rolled out flat? Should anything be put on to help preserve it? Thanks
Old 09-05-2018, 10:38:35 AM
DieselAddicted DieselAddicted is offline
Default Re: Flat belting
Roll it up. If it has a hinged splice start by folding it there and you should have a 3-5"hole in the middle depending on the belt.Tie the outer end down with some twine. Store it where mice cant get to it and the drier the better especially if it is leather.
Old 09-05-2018, 12:21:12 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
Leather should ideally be rubbed down with Neat's foot oil (available at most farm stores) to keep it from drying out too badly. As for the canvas-style belting, I personally think the best thing is to simply use it periodically to prevent it from becoming too stiff. You may even consider running it for 5-10 minutes on both sides so it doesn't take on a permanent bend only in one direction.
As DieselAddicted mentioned, keeping them rolled up is preferred. Most all of the threshing machines had a reel somewhere for rolling up and storing the main drive belt. I have several corn grinders and I roll the belts up and store them inside the hopper so they don't get lost (also make sure all the corn is GONE before storing the machine).
The Following User Says Thank You to Jebaroni For This Post:
Old 09-06-2018, 08:24:45 AM
Old Iron Dave Old Iron Dave is offline
Any ideas on what to use on a canvas belt that has gone way to stiff to run?
Old 09-07-2018, 08:08:46 AM
Jebaroni's Avatar
Good question...I'm curious myself. Is it the "pure" tan canvas, or a black rubber belt with a fabric covering? I'm wondering If some form of rubber conditioner would work, but unsure of how $$$ it would be?
Old 09-07-2018, 09:19:09 AM
I have the tan canvas belt. It's only about three inches wide and maybe only12 feet long (can't tell for sure, to stiff to unroll). It's not worth much, but would be a shame to junk it if it can be salvaged.
Flat belting how-to's Steam Pig Farm + Industrial Antiques and Collectibles 3 05-17-2016 10:34:55 PM
Flat Belting mightgo Smokstak Down Under 4 01-17-2015 06:37:59 PM
Flat belting supply? E27N Smokstak Down Under 6 06-04-2012 12:31:12 AM
Flat belting source Bryan Grube Antique Gas Engine Discussion 5 03-01-2009 09:55:58 PM
Flat Belting Material Larry K Antique Gas Engine Discussion 2 03-06-2008 07:16:23 PM
